Destroyed engine question
Old Jun 7, 2018 | 12:08 AM
Daniel817's Avatar
Default Destroyed engine question
i have a lq4 with 243 heads along with a 228r cam, long tube headers along with a nubs intake with ls7 throttle body. I drove with it for almost a year with no issues until recently. I added a stall and built trans in it and under wide open throttle would break the spark plugs. Never have had this issue before. Well after I got back home and drove the truck it died and locked up. Tore it apart and cylinder 7 piston was destroyed, #5 piston was deteriorating and #8rod snapped. Any ideas what would cause this?
Old Jun 7, 2018 | 10:33 AM
bammax's Avatar
You built up the trans and then didn't hold back as much as you used to and it finally gave up. I'm wondering if you dropped a valve or 2 and it became a battering ram in the cylinder.
Old Jun 7, 2018 | 12:29 PM
Daniel817's Avatar
no valves dropped. Only damaged due to prices of piston hitting the head and valves
Old Jun 7, 2018 | 12:46 PM
bammax's Avatar
I'd chalk it up to horrible luck and start sourcing another block. Hopefully you can snag something cheap and be back on the road relatively soon.
Old Jun 7, 2018 | 01:55 PM
Daniel817's Avatar
I allready have it in just gotta finish putting it back together. Reason for the question is I don’t want it to happen again
Old Jun 7, 2018 | 02:04 PM
RockinWs6's Avatar
Could be many many scenarios, stretched rod, worn rod bearings, broken piston. I'm gonna guess it went something like this.........WOT piece of a piston breaks off and whacks the spark plug-plugs. You replace plug-plugs continue running it hard WOT next time more piston breaks off jams piston against the head breaks rod. Could go a few other ways too. Moral of this story is GAP THE RINGS LOOSE if you are going to flog the crap outta it. Especially the top ring, the top ring got hot didn't have enough end gap and had to go someplace so it broke the piston ring land.<very bad
I've done the same thing BUT when it broke the piston I stopped driving it. You my friend made sure there was no doubt where this was going. When EVER you have a broken mashed spark plug you know big trouble is lurking.
Old Jun 7, 2018 | 02:14 PM
00pooterSS's Avatar
Looks to me like the bottom end went dry, the bearings went to **** which allowed the pistons to hit the heads.
It's also why you have a rod snapped, if the bearing seized it'll grab and snap the rod
Or you were revving it too high and the rod bolts stretched and caused all of the same scenario from bearings getting wiped out and seizing.
How high were you revving it? How much oil was in it?
Old Jun 7, 2018 | 03:01 PM
Daniel817's Avatar
Had launched it and it was at 6k about to shift into second. The first time it happened I used a scope inside cylinders and nothing out of order. And it was at full line.
Old Jun 7, 2018 | 03:02 PM
Daniel817's Avatar
Engine still rotated freely
Old Jun 7, 2018 | 03:08 PM
00pooterSS's Avatar
Sounds like I guessed wrong. A ring land breaking is a possibility but you usually don't see that on NA motors.
What happened the first time?
It's possible you broke a ring land and pieces went into the intake and went into other cylinders.
Old Jun 7, 2018 | 03:12 PM
Daniel817's Avatar
Just missfiring due to messed up plugs. Only happened on wot. Driving it normally drove fine
Old Jun 7, 2018 | 03:58 PM
1FastBrick's Avatar
Detonation.
Old Jun 7, 2018 | 04:18 PM
00pooterSS's Avatar
Messed up plugs wouldn't only misfire at WOT so I agree with 1Fastbrick
Detonation would hammer the pistons, rods, and bearings
Old Jun 7, 2018 | 06:13 PM
bammax's Avatar
Where did the engine come from and what did you do to it before putting the performance parts in it? If it was a junkyard motor with no known history it may have just been waiting to blow. I've seen a few junkyard motors that seem fine until you run them hard and they start to show how beat they are.
Old Jun 7, 2018 | 08:05 PM
KillerKustums's Avatar
that's what is was wondering if the bearings were wore letting **** go farther than it should. But with the rings pushing together man can something simple like that mess a lot up. Wow! Would this be from heat shrinking the clearances together?
Old Jun 7, 2018 | 08:17 PM
RockinWs6's Avatar
The factory ring gaps are set too tight, its so common to have that top ring land come off. Plus number 7 cylinder runs hot to start with. If it were me I'd be adding quite a bit to the ring gaps if you are going to run hard WOT all the time. Happened to me number 7 broke the land and it happened fast. Of course I didn't run it after I seen the plug was mashed. Once the piston looses a ring land its not long till the piston fails<see results above>
Old Jun 7, 2018 | 08:52 PM
99 Black Bird T/A's Avatar
How did the converter look? What was the clearance on the prior install with the old motor?
