Quench too tight?
Shop took .002 off the deck, so the pistons are now out of the hole about .008-.009.
Thinking about running a .040 cometic...will this be too tight for quench? Won't be spinning it more than 6700...street car that will see the track once a month at most.
I've read alot of .035 targeted quench on here...how would you feel about .031 ish?
How long you been doing that for? Do you let everything get to operating temp before revving it. Any signs of it being too tight or is it all happy inside the sbe?
I have been doing it for a couple seasons now with zero issues including a road course event (Power Cruise) where my car lives from 6-7000 rpms for about 10 min straight, 2 sessions a day for 3 days if that gives ya a idea on how I drive my car lol.
I'm no professional engineer builder but have talked to a couple local and .030" + seems to be safe. .030" and below you are cutting it closer and closer. I was originally going to run around .025" quench but decided to play it a bit safer being on sbe including rod bolts and knowing how hard I drive it. My tuner also says I'm more than fine at .033"
I always let it get to operating temperature before going wot.
Fully agree
The benefits will be very very negligible, and if it's too tight, you're looking at potentially grenading the entire engine. Juice ain't worth the squeeze, not even remotely.
If I confirm that, I'll be going with the cometic .045 and targeting .035 quench
Thanks gentlemen
