BTR TFS 220's EPS Cam... WHOOPS!
#181
Was it set at 24 because it wasn't really making any power beyond that, or is there some other reason? Another thing I've noticed is that really good heads don't need as much timing. I wouldn't be surprised if more timing does absolutely nothing for performance
#182
#183
It was just set at 24 to have a safe start to dyno tuning. Never got a chance to do that, so I'm going to bump it up to 26 and do some street pulls to test. It probably won't be worth a ton, but even 5 rwhp is worth it if it's safe. I'll get it back on a dyno to see the difference soon.
#184
Moderator
Received 1,838 Likes
I was also going to mention more timing is not always more. My Mamo heads only wanted 23 degrees with the fast intake. I could run 26 without Kr but made best power at 23.
Oddly enough, went to msd intake and it liked 26.
#185
Yeah as long as you know that it's completely safe then why not. Plus acceptable max timing on the street might be a little less than on the dyno. I know it was in my case
#186
Moderator
Yup. 12.7 at peak torque and 13.0 at peak power.
#188
Originally Posted by Jtm2085
My car with the tfs220s made peak power at 26* and lost power at 28
#191
Thanks for the interest. I was surprised to see the thread pop back up! I have no new dyno numbers yet, just the 450/400 it did on the Mustang dyno in October. I have done some additional track tuning though. So far my best time is an 11.73 at 122.4 mph in the 1/4. That is with a 1.97 60' on my 315/35 18 Toyo TQ drag radials. The DA was about 1500 at the time of the run. I haven't weighed the car yet, but I expect that it's at least as heavy as stock. The little weight reduction I've done has been offset by the rear, larger wheels, heavier aftermarket heads and intake, and of course the sub and amp in the rear. It was raced as I drive it on the street.
The following users liked this post:
bigsapper (07-14-2019)
#192
Out of curiosity did you notice a slight drop in your oil pressure after using those 2110 lifters? Mine dropped just the slightest bit warm idle at 25 - 28 psig WOT goes over 60psig. We have such similar builds lol, I haven't ran mine at the track yet but on the street it has held its own.
#193
