Another bore question
Old Jul 25, 2018 | 01:07 PM
Match360's Avatar
Default Another bore question
I have scoured these and other forums for a answer to the boring capabilities on aluminum 5.3's.
I've got an LM4 2004 from an Envoy with 1 rough cylinder and was wondering if anyone can confirm that these have the thicker cylinder walls?
Casting of block is 12566910
Seems to be all kinds of conflicting information on every thread I found.. Just would like a heads up if I'm wasting my time as I have a Iron block I can use if need be and I'm nowhere near a quality machine shop to seek advice.
Old Jul 25, 2018 | 01:13 PM
00pooterSS's Avatar
I'm not certain but I'm pretty sure they are thicker and can be bored. Wish I had a definite answer for you. Maybe KCS knows.
Old Jul 25, 2018 | 01:24 PM
pantera_efi's Avatar
Default GEN-IV 5.3 = 98mm Bore
Hi 360, I often Bore a GEN-IV 5.3 to 98mm AFTER a Sonic Test is done.
I can supply a RaceTech Forger piston of lower/equal weight ?
Lance
Old Jul 25, 2018 | 02:15 PM
I have heard, BUT this might be "internet gospel", that the same block is used for 5.3's AND 6.2's. which means they can be bored out. But don't take my word....
Old Jul 25, 2018 | 02:18 PM
The question is how far do you need to go to clean it up?
Old Jul 25, 2018 | 02:24 PM
This might cost a little, but bore the affected cylinder as far as is usually safe. If the damage is gone, bore the rest of the cylinders, If still there, trash the block, OR put in a new liner.
Old Jul 25, 2018 | 02:38 PM
A lot of the 5.3 aluminum blocks are seimese bore blocks. Not all of them, but a lot are. I think you have an LM4 block. You can use a flashlight, and look into your water jackets on the block deck. If your cylinders are molded into one big unit, meaning there is no gap between the liners inside the water jackets, then that block can be safely overbored quite a bit. There are guys over on YellowBullet that have (I do not advise) bored those blocks .125”. It’s pretty common to see them go .030”, if it’s one of the thick liner blocks. I guess you need to figure out which block you have, and how far you need to go.
Old Jul 25, 2018 | 03:17 PM
Match360's Avatar
I have read the same.
Old Jul 25, 2018 | 03:22 PM
Match360's Avatar
There is sorta a gap between the liners but considerably smaller and different than an iron block I have sitting here and looks like a one piece deal? I'm just gonna try to let a machine shop check it out I guess.Thanks folks
Old Jul 25, 2018 | 04:44 PM
What shop you using? Where are you in Ga?
Old Jul 26, 2018 | 07:18 AM
Match360's Avatar
I'm in Springfield, just outside of Savannah.I've been talking to a guy in Register
