Should I change the cam
doing a swap into a 78 Vette. Using an LM7. Plan to upgrade the intake and use headers. My question is...while I have the engine out, does it make sense to change out the cam. Thinking of does but looking for opinions...I don't have a ton of experience here.
Thanks in advance...JP
I’m trying to avoid doing any major head work to accommodate a new cam so it’ll be interesting to hear their advice.
Go drive a truck.
Is THAT what you want a Vette to be a duplicate of?
Not that there's anything "wrong" with the LM7; for what it's meant to do, it does a reasonable job; but it would make just about as much sense to pull a 327 out of a derelict school bus and drop it into a 60s Vette, as doing the same thing with 2000s parts.
For the Vette, get a cam/springs kit from some one of the suppliers you see people talk about on this site. TSP, BTR, Vinci, CamMotion, Livernois, ws6store, etc. They know THESE motors specifically and understand with they want. Also get a converter; it's ASTOUNDING how much difference a properly chosen one of those can make. And consider rear gears as well if you have less than 3.42s in that 78, as is likely.
There's nothing wrong with the LM7 intake. In fact almost anything you can do to it will be a DOWNGRADE. If it'll fit under the hood, leave it alone.
And also right, a 78 Vette is the absolute poster child for what the Frod people call the "plastic pig". Even a stock truck LM7, that idles as smooth as a baby's butt and runs out of steam before it really gets going good, is STILL a world better than a L48. But it still would DRASTICALLY benefit from a cam upgrade, just as a school bus 327 would have, before going into a "sporty" car.
Intake fitment would depend on what hood the car in question has... even a stock hood, wouldn't surprise me if it would at least come mighty close to a fit, with the possible exception of where it locates the TB.
My son and I are building this as a project car to learn on. Just want something that isn’t too expensive, relatively reliable, and isn’t a complete turtle on the road.
If there are more suggestions I’m all ears. I’m definitely going to move forward with the cam and springs...I found a newer style intake complete with fuel rails on eBay that I am considering as well.
Another question...what is the best way to deliver fuel to it?
ive seen a bunch of discussions but it’s not clear to me whether or not I should totally remove the stock in tank fuel pump and just add an external electric one or some other combination.
Again...any thoughts are welcome! More details the better!
IMO just get a new LS6 stock GM cam along with GM Blue springs (LS6/LS2) and have a blast. Cheap and easy with all GM parts. Revs all day to 6500 with joy and provides a little under 400 flywheel.
Fueling is very car specific. See if there is a company that makes a retrofit FI capable fuel tank and go from there. Don't be shocked when the fuel system costs more than the motor
There is a substantial power gain that can be realized on a stock LM7 with a camshaft upgrade. 70-100 HP is possible. Have a look at our Titan Series of camshafts:
http://www.cammotion.com/camshafts/t...nce-camshafts/
If you have any questions, just reach out to me: Steven at CamMotion.com
If you choose to do it later you'll wish you had done it now
One really nice thing about doing it now, since you don't want to get into the heads, is you can turn the motor upside down on the engine stand while doing the cam swap and not have to worry about a lifter dropping into the block when you swap the cam with the heads on.
And definitely get with cam motion
for $1100 you can get the intake, carb, and ignition controller and not have to deal with the EFi stuff since its not going to be a daily driver or anything, just throwing that out there
I plan on changing the C10 from Carb to FiTech this fall. Stock truck intake manifold with external AEM fuel pump.
