Summit engine blocks
https://www.summitracing.com/parts/sum-150157
Summit purchased most all (from what I read) of GM’s remaining LS overstock blocks, when GM officially shut down the LS line, and re-tooled for the LT line. It’s not a Summit block. It’s a GM block sold by Summit.
Plus it's nice having a seasoned block as well.
Do your homework. You can buy an assembly cheaper than buying parts separate. For performance and reliability you’ll want to bore the block to your pistons size, not buy the pistons for the bore size you have. Enjoy the journey. Ask questions along the way. Have fun with the hobby, because that’s what it’s supposed to be...fun!
My current ls1 only has 30,7xx miles on it and is running fine. I'm running 10 psi right now, but plan to keep slowly adding boost over time. I don't expect to build a 100,000 mile engine. What I want is a motor that will handle 700+ rwhp using a procharger and auto trans reliably. For every junk yard motor making 1000+ rwhp posted all over the internet there are several more stories of them blowing up that are never told.
It's summit, they shouldn't have issues with machining, they aren't a two bit corner store if you smell what I'm cooking.
If you're real concerned drop it off at the machine shop to be inspected.
I say buy the block and build your motor man.
Sorry, I have no experience with that specific block to answer your original question.
Also, for others who have said it. You can't buy a built shortblock for less than you can build your own. Most machine shops will hone/bore with a torque plate the pistons and balance the rotating assembly for about $500. Cleaning of the block $50. Add a line bore if you do ARP studs. Another 200 or so for that. If the block needs more work that that, it's not worth it. Get another one.
And most good rotating assemblies are in the $2000-2200 range with K1/Molnar/Compstar Rods/Crank and Wiseco pistons with upgraded pins. Plus whatever the block costs. Then the bearings and ARP studs. Another $350 for that.
What does that come out to? About $3600. See who will build you an all forged shortblock with ARP mains, upgraded H-13 pins, and a 5.3 or 6L block for $3600? Nobody. Tack on another $1k to that AT LEAST. Plus shipping.
Your statement above leads me to believe that you don't have any of the tools required for measuring clearances in the engine. So I have to ask the question. Are you aware of the tools and processes required? This is a question you have to answer to yourself, not me. I don't need a reply.
I do have to reiterate, learning to build an engine the right way, the first time, will cost more than simply buying one. Unfortunately, "budget build" "first engine build" and "700 at the wheels through an automatic" can't realistically be used in the same conversation.
