Good valve control, pushrods lifters
Old Aug 30, 2018 | 07:11 AM
99blkfrc99's Avatar
Default Good valve control, pushrods lifters
I'm going to be ordering some PRC 227's very soon and as long as I'm in there I would like to get pushrods and lifters. Would like to spin it to 7000. Has torquer V2 already. What would you guys recommend for lifters and diameter pushrods? Thanks.
Old Aug 30, 2018 | 07:41 AM
Darth_V8r's Avatar
Moderator
Spring pressures affect pushrod selection. For a safe bet, i would go manton series 5 11/32, non-tapered. maybe slightly clearance the bosses for good measure while the heads are off.
I like the Johnson short travel lifters, but they get expensive for most people's tastes. However, the valve control is tremendous with them.
Old Aug 30, 2018 | 08:14 AM
KCS's Avatar
KCS
Moderator
I would think the PRC’s would have enough room for a 3/8” pushrod. I use BTR .080” wall 3/8” pushrods in almost all of my builds, and they’re barely more expensive than 5/16” pushrods.
Old Aug 30, 2018 | 09:16 AM
Darth_V8r's Avatar
Moderator
If the room is there, for sure
Old Aug 30, 2018 | 09:38 AM
handyandy496's Avatar
Yeah at 7000 a lot I'd want the .080 wall. They have served me well even with the little extra weight. Moral racing $lifters$ and rev to the moon!
Old Aug 30, 2018 | 09:51 AM
99blkfrc99's Avatar
I'll send them a message and see if 3/8 clears. Thanks.
Old Aug 30, 2018 | 11:07 AM
KCS's Avatar
KCS
Moderator
FWIW, I’ve drilled out stock heads and fit 3/8” just fine.
Old Aug 30, 2018 | 11:17 AM
Broken944's Avatar
Weight on the pushrod side isnt that big of a deal, go 3/8 if it fits. They may be a bit pricey, but Morel's 5206 should be able to handle 7k all day long.
Old Aug 30, 2018 | 11:18 AM
MuhThugga's Avatar
Trend 3/8 pushrods clear stock heads just fine.
Old Aug 30, 2018 | 06:17 PM
Dragls's Avatar
You have to clearance for them. They will not work on a "stock" head.
Old Sep 1, 2018 | 11:13 PM
garygnu's Avatar
if the 3/8 dia fit ,also consider ,is the block or heads decked any ? what head gasket you using ? I suggest buying a pushrod checker tool ,to get the optimum push rod length for better valve train stability ,and make more power .thats what I have learned reading all the great threads here .
Old Sep 2, 2018 | 12:56 AM
8.Lug's Avatar
Manton 11/32” are .120 wall. No need to clearance for 3/8 pushrods.
Old Sep 6, 2018 | 07:01 AM
MuhThugga's Avatar
Tell that to my 821 and 862 heads with Trend 3/8" pushrods.
Old Sep 6, 2018 | 09:10 AM
KCS's Avatar
KCS
Moderator
Ditto. I have BTR 3/8” pushrods in a set of 317 heads. It’s tight but it clears.
Old Sep 6, 2018 | 11:39 AM
slogo's Avatar
I have BTR 3/8 pushrods in
totally stock 243’s
Old Sep 6, 2018 | 01:18 PM
8.Lug's Avatar
7,000 isn’t very fast and .600” isn’t that much lift. For reference, I’m spinning to 7,300 with a .600 lift cam using Manton 11/32 .120 wall pushrods. Not even using double springs, just single beehives. And I bounce off the rev limiter with what I do. Perfect control.
Old Sep 6, 2018 | 01:40 PM
Well that should settle a lot of the anti-beehive BS. .600 is getting to be pretty much a normal lift for LS setups. And for them to go to 7k RPM is saying something too!
Old Sep 6, 2018 | 02:41 PM
Jenson's Avatar
I rev'd my 5/16 .08 p'rods, 228/232 XeR lobe, 26918 with TS retainers, LS7 lifter, ported 241's 5.7L to 7.3K daily! I miss that car. If you go radical on the cam you can still stay single with the comp conical springs too
Old Sep 6, 2018 | 07:55 PM
99blkfrc99's Avatar
I'm just trying to stay light and strong for valve control. I know 7k isn't too high but that's about the powerband I want to stick with. Cam peaks around 6100. I really like the cam, that's why I'm sticking with it. If I could get away with a single beehive that would be good, less weight. Which does anybody recommend? Thanks.
Old Sep 6, 2018 | 08:14 PM
Darth_V8r's Avatar
Moderator
Psi1511 for weight and longevity. Friend of mine did psi 1511 and titanium keepers took over a pound out of valvetrain.
