Engine lower rotating assembly installed. Quick question
Old Sep 15, 2018 | 04:12 PM
Soflown's Avatar
Default Engine lower rotating assembly installed. Quick question
Just finished installing my rods and pistons on my 2002 6.0L LQ4. First V8...I know what your thinking.
I have built engines before, but was in the 4 cylinder realm. So now we are past that, I noticed something, which maybe normal. For every piston I installed, it became more and more difficult to rotate. I checked all the rod bearings with plastiguage and the rod to crank clearance is fine. It seems to be dragging hard on the rings and when I rotate the engine, some of the pistons are chattering in the bore. Also, everything is installed with brake in lubricate and oil. If I can give a rough estimate on the amount of torque I would say I dropping about 120 to 140 ft pounds to rotate it. Am I just freaking out for no reason.
-Fresh block 10 over and deck paralleled.
-Rotating assembly balanced.
-Dimond pistons and TSP rods.
Old Sep 15, 2018 | 06:18 PM
s30.hybrid's Avatar
Sounds like you’re talking just the short block right? No heads yet? That kind of effort sounds extremely high for a short block to me. Crank with torqued mains should be smooth to turn by hand. It will get progressively tighter with each piston but I wouldn’t expect as right as you’re seeing. Once the heads and valvetrain go on thing do get extremely tight especially with aftermarket valve springs. Are you sure the rods are orientated correctly on the rod journals? Do you know what you piston/cylinder clearance was machined to?
Old Sep 15, 2018 | 07:04 PM
Philhippy45's Avatar
I've been down this same road with my lq4 408 stroker build. As I put all the pistons in it did the same thing yours did. I checked the mains and rod bearings and all were installed right and clearance were great. No scoring on the wall no nothing. So I went ahead and installed every thing and now it's in the engine bay. Hard as hell to move with a torque bar but the starter moves it just fine. And after cycling the engine several times to get oil flowing it got a little easier to move by hand. I changed the oil and used a magnet and found no metal once so ever in my oil. Im sure if something was wrong their would be something in the oil. So Idk what my issue was it was the same as yours but every thing seems ok.
Old Sep 16, 2018 | 10:06 AM
RockinWs6's Avatar
Did you mic all the pistons to the bores? did you check all the ring end gaps in the bores? 140lbft to rotate doesn't sound right to me, maybe 20lbft to break free but once turning it should feel fairly easy to turn in my world. Make video of this and pistons chattering.
Old Sep 16, 2018 | 02:32 PM
Soflown's Avatar
well I did find the issue..."over confident me assumed when I had given all the parts to the shop and they pre-assembled and rotated the block and make sure everything fit that they also had filed my piston rings. I removed one of the Pistons and tested upper and lower ring in the bore and found that it actually had a positive overlap on the rings. This was a juvenile move and I should have took my time and not assume that the shop had taken care of me. Lesson learned the hard way.
Old Sep 16, 2018 | 02:36 PM
Glad you caught it now. Wouldn’t have lasted long...
Old Sep 16, 2018 | 02:56 PM
s30.hybrid's Avatar
Good catch! Were these advertised as drop in rings?
Old Sep 16, 2018 | 03:16 PM
slogo's Avatar
Wow, wish you had a picture of that, I can't see a positive overlap ring even fitting in the bore, maybe I'm not getting
exactly what you are saying.
Old Sep 16, 2018 | 07:30 PM
RockinWs6's Avatar
You can send me the check for savin yer butt in any amount you like.
Old Sep 16, 2018 | 09:52 PM
RockinWs6's Avatar
Originally Posted by s30.hybrid
good catch! Were these advertised as drop in rings?
huh?..........
Old Sep 16, 2018 | 10:33 PM
s30.hybrid's Avatar
I was just wondering how setting end gap could have been overlooked by a machine shop, or at least communicated to the engine assembler (customer) that it hadn’t been done yet. I could almost understand if they were advertised as drop-in (requiring no file fitting), but even then it would be worth a quick verification. Glad the OP caught it. It would have meant a catastrophic failure otherwise.
Old Sep 20, 2018 | 10:21 AM
Soflown's Avatar
Heres the picture
Old Sep 20, 2018 | 01:34 PM
bbond105's Avatar
I learned a long time ago to never trust any machine shop’s work. Always recheck everything yourself.
Old Sep 20, 2018 | 10:29 PM
s30.hybrid's Avatar
Good thing you caught it!! Cross hatches look good!
Old Sep 21, 2018 | 12:23 PM
trik396's Avatar
Are you sure you are using the correct rings ? I've never assembled an engine where the rings were butted against themselves. There is always a slight gap that usually needs a little filing for the correct ring gap for your particular application
Old Sep 25, 2018 | 08:53 PM
LLLosingit's Avatar
I'm not sure why you think the machine shop would gap your rings in the first place. They need the rotating assembly for balancing and piston to bore fitment but they would have no reason to put the rings on the piston or measure them for you, That's part of the short block building process and it doesn't sound like you intended to have them build it.
Old Sep 25, 2018 | 09:53 PM
s30.hybrid's Avatar
Hey you’re absolutely right! I never had any intention of having the machine shop build this engine for ME lol. However, when the OP mentioned the machine shop pre-assembled the engine, you would think they would have caught this (maybe they did) and offered to gap the rings for a small fee. But yeah, I agree that the person doing the final assembly should catch and correct these issues (which luckily he did!)
Old Sep 25, 2018 | 11:56 PM
01CamaroSSTx's Avatar
It could have been a whole lot worse but common sense told you something wasn't right so I'm giving you an ahh **** and an atta boy!!!
Old Sep 26, 2018 | 09:39 AM
KCS's Avatar
KCS
Moderator
It’s common with forged pistons. I’ve used Wiseco pretty often and will usually get “file fit” rings, which are generally about .005” over the bore size. Right out of the box, they’ll overlap like that. You have to check them all too, even the oil rails as I’ve encountered those on a few occasion to overlap as well.
Old Sep 26, 2018 | 10:10 AM
slogo's Avatar
so when these rings are overlapped do
they fit in the ring grooves in the piston?
