Front welch plug #%#^@
Old Nov 5, 2018 | 11:44 AM
Rick5.3's Avatar
Default Front welch plug #%#^@
ok this is starting to **** me off. So im doing a full rebuild on lq9. I knocked out the rear barbell and front welch plug for cleaning purposes. I went with the upgraded metal barbell from sac city corvette. Now when i went to get the front welch plug no one carried brass 5/8 freeze plug. So i opted for steel. Whaddya know its not 5/8 its actually 41/64. So i ordered a few steel plugs off ebay. Install one, it goes in tight..im happy...then just to be sure i stick i screwdriver in the threaded galley hole to its right and apply a little pressure to see if it is in there goodandtite..SOB pops out ok so i try another..same result its like it goes.in tight like its supposed to but ypu can pop it out very easily
..so i said **** it and put some black rtv around one and drove it in. The front timing cover will keep it from coming out. Am i doing it wrong by using steel and not brass? My issue is i cannot find the brass plug anywhere except in a kit thats $20. I dont need a whole kit i just need one #$#$% brass plug! Anyone know where i can get a brass front welch plug by itself and not in a kit full of crap i dont need?
Old Nov 5, 2018 | 01:09 PM
Kfxguy's Avatar
man I'm a cheapass, but I'd spend the $20 to do it right rather than chance it, have an issue, have to tear it back down and spend $20 anyways. Plus coolant and gaskets. and Time. This is if you cant find the right plug by itself of course.
Old Nov 5, 2018 | 01:24 PM
KCS's Avatar
KCS
Moderator
I always reuse that front plug.
Old Nov 5, 2018 | 01:28 PM
truckdoug's Avatar
stake the edges with a chisel
Old Nov 5, 2018 | 01:29 PM
truckdoug's Avatar
tap it 1/2-14 npt and plug it
truckdoug's Avatar
hammer a piece of driftwood in there
truckdoug's Avatar
fill it with jb weld
Old Nov 5, 2018 | 01:38 PM
MY_2K_Z's Avatar
I approve this method.
Old Nov 5, 2018 | 01:51 PM
Rick5.3's Avatar
yea its not the money its the principal..im a stubborn ******..ill probably end up buying the kit but i will bitchin the whole way..i just dont understand why its so hard to.find a simple freeze plug
Old Nov 5, 2018 | 01:52 PM
Rick5.3's Avatar
i honestly was considering this...i can buy the tap and plug for cheaper than the damn freeze plug
Old Nov 5, 2018 | 01:53 PM
Rick5.3's Avatar
yea my dumbass lost the old one
Old Nov 5, 2018 | 01:54 PM
Rick5.3's Avatar
what about a wine cork? Would that work?
Old Nov 5, 2018 | 02:11 PM
qweedqwag's Avatar
The end of a douche nozzle will work.
Old Nov 5, 2018 | 02:19 PM
For about as long as you think it will..... lol
Old Nov 5, 2018 | 02:25 PM
sjsingle1's Avatar
i dont know about that plug....but the plugs on the head are not standard size so best to stick with OEM
Old Nov 5, 2018 | 02:33 PM
Kfxguy's Avatar
I bet it’s metric.
Old Nov 5, 2018 | 03:20 PM
SacCity, the place where you bought your barbell, also makes a front o-ringed plug for this location. It’s trick!
Old Nov 5, 2018 | 04:00 PM
DietCoke's Avatar
Nothing like a metal barbell to fix a problem that doesn't exist. Sales 101: Sell you a problem then sell you a solution.
Old Nov 5, 2018 | 04:19 PM
Its a great product. Gives you zero chance of leakage, and when you rebuild next time (a lot of us do) it comes right out. The front cover actually holds it in. I hate those stupid Oem expansion plugs. Hard to believe that it took someone 20 years to Come up with a better way to control oil flow in the LS platform.
Old Nov 5, 2018 | 04:31 PM
truckdoug's Avatar
why spend $3 on a non problem when you can spend $19 on it?
