6.0 with 5.3 crank ???
As you say yourself, you joined this forum to learn this stuff. So in six years, why didn't you?
As for your last comment, none of us here are your female friends, so knock off the focused profanity.
In short yes, this works but you should balance the crank as the 6 liter pistons are heavier. It also matters as gen 3 and gen 4 are not interchangeable piston wise (one is press fit one is not). If your using a gen 3 crank with a gen 4 pistons and rods you should definitely re balance as they are heavier than gen 3's.
What i was trying to explain to him is that it wont work properly unless he re balances it. Guys have done it without but for how long does it last idk.
He does ask "First can it be done and second what would you have if it can." which i assumed means he wants more of an explanation.
Having said that if you can read OP's mind by all means tell me.
