Checking ptv
i measured 7.33” for zero lash/preload on the rocker arm.
question: if I’m going to use hydraulic lifters with .070” preload, do I measure ptv with preload or zero lash, do I use the 7.33 or 7.4” pushrod for checking
Pushrod length used doesn't really matter as long as the rocker is riding on the valve tip in the appropriate position.
ive been doing it wrong and adding preload on to the solid lifter
WARNING: Ensure lifter is down during crankshaft movement to prevent hitting pistons during crankshaft rotation Move adjustable pushrod to exhaust lifter
Install rockers after obtaining zero lash using the appropriate shims required for correct wipe pattern
Rotate motor 340o (20o before end of exhaust stroke) pushing down on lifter to ensure valve closes and follows lobe of cam
Install dial indicator to measure movement of exhaust retainer
Rotate motor in 2o increments, measure PTV for each increment until 20o after piston passes top of stroke
Remove dial indicator and rockers
Measure adjustable pushrod overall length & gauge length
Install adjustable pushrod on intake valve
Rotate motor two turns stopping to 20o before piston is at top of overlap stroke
Install rockers and adjustable pushrod/verify zero lash
Install dial indicator on intake retainer
Remove adjustable pushrod
