Head Gasket for .020 bore
Old Jan 21, 2019 | 06:57 PM
volsfan32119's Avatar
Default Head Gasket for .020 bore
If my block is bored .020 over do I need a different head gasket or will stock work?
Old Jan 21, 2019 | 07:06 PM
01CamaroSSTx's Avatar
I don't believe you will be able to since the stock size head gasket bore is 3.910. Assuming we are talking about an LS1 5.7 bore you will need to be looking at a 3.93 or greater bore head gasket.
Old Jan 21, 2019 | 07:09 PM
That's what I was thinking but it would need to be 3.98 right?
Old Jan 21, 2019 | 07:13 PM
Cometic GM Gen III/IV Small Block V8 LS Series .051" MLS Cylinder Head Gasket, 3.970" Gasket Bore.
Old Jan 21, 2019 | 07:19 PM
I assume your running an aftermarket piston. What size bore does your pistons call for?
Old Jan 21, 2019 | 07:21 PM
I didn't know you could bore an LS1 sleeve to .020 either.
Old Jan 21, 2019 | 07:29 PM
Yep that's what I thought also when my engine builder said we could. When I questioned it his exact words were "stop reading the f'ing internet" and also said "why do they make pistons for it if you can't do it". He is a very respected builder around here so I said good enough for me. The motor has ran good since the rebuild but I had a lifter fail so I had to pull the heads and I'd rather not reuse the old head gaskets. The gaskets that are there are Fel-pro 9284PT. Those do show a 3.99 bore so I guess I will just reorder those. Thanks for your help.
Old Jan 21, 2019 | 07:35 PM
I've heard the 99 LS1's had thicker sleeves and could be taken to .020 so that may be the case here.
Old Jan 21, 2019 | 07:37 PM
Mine is 2001
