Camshaft Crossroads - Summit Comparison
Actually looking for a cheap set of 799's if anyone has a set laying around...
LS1Tech Sponsor
Received 1,169 Likes
why do you say he will be leaving alot on the table? i talked with summit and they said the 3200 stall would work very nicely with there stg2 cam. i sometimes fine that a 4000 is a little lazy on the road but at the track it might shine more then on the road. maybe a 3600 is a happy place.
This thing had an ARP balancer bolt. I think it was the hardest one I have ever wrenched off. Took the old cam out and made a mistake and looked at the cam bearings...
What assembly lube do you guys use on your cams? For roller cams I have always used the same oil that goes in the crank. The Summit cam box is saying to use extreme pressure lubricant. What say you?
