Which cam for my 06 L33
Old Mar 8, 2019 | 10:08 AM
Novapat67's Avatar
Default Which cam for my 06 L33
I am finally getting around to swapping an 06 L33 5.3 into my 65 nova 4dr. I had been pretty set on the 228r cam from TSP, but I know it is a pretty old design. Old, but good and popular. Are there any other newer cams I should be looking at?
Here are some specs on the car:
65 nova 4dr
8.6 10 bolt rear with 3.42 gears and disc brakes
Mini tub with 275 rear tires
CBR lower control arms and power rack
4l80e with 3200 Circle D 278mm converter
2006 L33 5.3
TBSS intake w/ 90mm Tb & flex fuel injectors
This is a fun street car I intend to be a daily driver.
Old Mar 8, 2019 | 11:07 AM
If you want a bit of lope to it and smooth power delivery from about 12-1500 on up, try the WS6store High Lift Hot Cam. It's basically the GM LS Hot Cam with .600 lift instead of .525. The added lift made it a much better and still contemporary cam.
Old Mar 8, 2019 | 11:19 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Thanks atsma. Our high lift asa made around 350 or 360 rwhp in an l33 swap previously and it has a very nice cammed sound too.
Old Mar 8, 2019 | 11:43 AM
omc8's Avatar
2x on the above-mentioned . may also want to look at the summit LS pro Ghost cam sum-8715
Old Mar 8, 2019 | 12:26 PM
Novapat67's Avatar
Awesome! Thanks for your input!
Do you happen to know any other specs from that build? Headers, intake, transmission, etc?
Old Mar 8, 2019 | 12:31 PM
Novapat67's Avatar
Excuse my ignorance, what makes these cams different from the TSP 228r? They all seem pretty close in specs. Maybe I am just splitting hairs here haha. Thanks for all the info!
Old Mar 8, 2019 | 02:01 PM
Summitracing's Avatar
LS1Tech Sponsor
There are quite a few things we take into consideration with the Pro LS cams. Each event is highly structured to achieve the behavior we're looking for. If you look at our SUM-8707 Stage 2 for instance (226/238 113 +3 .600/.600), we have the intake closing at 43 degrees and opening at 3 degrees to insure it's extremely tuneable. The exhaust opening if fairly early compared to most for more high end power, but we closed the exhaust at 3 atdc. to limit overlap to 6 degrees. Also for tuneability reasons and the fact that most of these engines are run with a full exhaust that can cause reversion if we close too late. Finally, our lobes are stable to 7500+ with the common .600 spring packs that have seat pressure in the 130-150 range. The power holds on longer and it's not hard on your valvetrain. If you wanted to back it down a notch, Mavn's done some awesome things with his Stage 1 Ghost cam....very calm cam for the power it produces.
__________________
800-230-3030
www.SummitRacing.com
Old Mar 9, 2019 | 09:01 AM
The specs. Our high lift asa cam will make more power than the 228r and have a better sound. its a 226/236. Single pattern cams may have been good for older engines, but going with a split pattern is a much better idea.
The l33 build is here in the thread
https://ls1tech.com/forums/generatio...r-5-3-l33.html
Old Mar 9, 2019 | 09:57 AM
Novapat67's Avatar
Very cool. Do you offer a kit with cam, springs, and pushrods?
Old Mar 9, 2019 | 12:21 PM
Yes we do. Its 569 shipped with beehives
Old Mar 9, 2019 | 04:21 PM
Novapat67's Avatar
Sweet. Is the consensus that beehives are sufficient for a can this size rather than double springs?
Old Mar 9, 2019 | 04:24 PM
Sweet. Is the consensus that vehicles are sufficient for a can this size rather than double springs?
You mean beehives? The answer is yes. As long as they can handle .600 lift.
Old Mar 10, 2019 | 09:19 PM
Novapat67's Avatar
After thinking about it a little more, I'm slightly concerned that this cam might be a little big for decent drivability. Once together, I plan to drive this car every day. I also forgot to mention that I'm running power brakes so I need decent vacuum. That being said, maybe it's not too big at all. Thoughts?
Old Mar 10, 2019 | 10:41 PM
I think for what you are describing, the High Lift Hot cam would be better. The ASA cam runs pretty ragged.
Old Mar 10, 2019 | 11:01 PM
springer_4's Avatar
I agree with G Atsma, Go with the WS6 Store High Lift Hot Cam you will not be disappointed Trust me.
Old Mar 11, 2019 | 11:28 PM
The asa cam works great with a 3000 stall and 3.73s. Our high lift hot cam would be considered an easier driving cam and will work with any stall and gear.
