Thoughts on my HCI build
Old Jun 23, 2019 | 03:54 AM
TBSOELS1's Avatar
Default Thoughts on my HCI build
Been buying parts for my HCI build for my 98 WS6 6 spd, this will be my first build I've done and just want someone who knows a thing or two to look over and give their input.
The meat and potatoes...
PRC 225cc as cast, 62cc chambers, no mil, .051 head gaskets
SNS Torque Max Stage 2 227/235 .618 .605 110+3
Vengeance Ported FAST 92/NW 92 TB
SE 1 7/8, ORY already on the car
C5r Chain
LS7 Lifters
WS6Store rockers w/trunion upgrade
ATI Balancer no underdrive
Monster LT1-S twin disk
What do you guys think? Just a street car/weekend warrior, wont see the track but maybe 1-2 times a year. Am I using the heads to their potential with the smaller cam? I keep second guessing myself on the cam and thinking about stepping up to the SNS 3 or BTR 3.
Thanks!
Old Jun 23, 2019 | 05:25 AM
Tuskyz28's Avatar
All looks good to me. I think them track visits will get you a low 11 sec slip.
Old Jun 23, 2019 | 05:51 AM
SLP IROC-Z's Avatar
If you dont mind spending more money on heads the trickflow genx 215s are hard to beat flow wise especially on the exhaust side.
PRC 225
LIFT INTAKE FLOW EXHAUST FLOW
.100" 68 CFM. 56 CFM
.200" 145 CFM. 113 CFM
.300" 210 CFM. 164 CFM
.400" 257 CFM. 200 CFM
.500" 300 CFM. 214 CFM
.600" 318 CFM. 229 CFM
.650" 321 CFM. 230 CFM
Trick flow genx 215 flow chart
File Type: pdf
Old Jun 23, 2019 | 05:55 AM
SLP IROC-Z's Avatar
Id talk to pat g or cam motion about the cam, have it custom tailored to your heads. Might as well step it up to the fast 102. I believe a tony mamo ported 102 manifold is about 1400 and is worth 20-25hp over a non ported 102.
Old Jun 23, 2019 | 05:59 AM
Tuskyz28's Avatar
X2 for Pat G. His knowledge is unreal.
Old Jun 23, 2019 | 07:15 AM
vettenuts's Avatar
Buy an adjustable pushrod for measuring and then measure and buy larger OD pushrods.
Old Jun 23, 2019 | 07:22 AM
TBSOELS1's Avatar
I guess I should clarify, I've already bought everything in the list I mentioned, just wanting input on what I have going however nothing is final since I havnt started the build yet. That's why I was wondering about sending the cam back and going a little bigger. Also I have bought an adjustable pushrod to check the length, what size (OD) should I go with once I determine length?
Old Jun 23, 2019 | 07:24 AM
Darth_V8r's Avatar
Moderator
If you are only planning a couple track outings a year, keep the cam smaller. You gotta love with it the other 363 days of the year. Sns2 is a great cam. There are a few others worth checking out also with less chop that will be easier to drive and tune
228r
Titan4
Ws6 store asa
Street sweeper ht
Old Jun 23, 2019 | 07:30 AM
Darth_V8r's Avatar
Moderator
You treed me. If you already have the sns I recommend running it
Old Jun 23, 2019 | 07:49 AM
TBSOELS1's Avatar
Thanks Darth, its always good to hear peoples input on these things to help me make up my mind. I don't want to be disappointed in the thing after all the money spent.
Old Jun 24, 2019 | 08:33 AM
TBSOELS1's Avatar
vettenuts, what size pushrods should I get? Didn't realize you could get different thickness pushrods
