Had to go 0.065 over LQ4 6.0 block =11:1cr 376" for less than $1000 all day build
#62
Stock stall, pretty much stock everything! I just finished tightening up the crank bolt, I managed to clean it up with the tap pretty good, I covered the bolt threads with loctight and jammed it in. I've never had to do that to my LS1 lol this guy is making some twist!
#63
Original Cam and main bearings are still in this 2001 Lq4 block after the catastrophe that took it out (#7 piston and rod came apart and gouged the bore) and I'm still running them with the new 4.065 bore and hone. I dropped the crank in it from my old L59 that had a spun #3 Camshaft bearing along with the used floater rods with used 4.8 rod bearings and the new pistons and rings I bought. Installed in the car now the engine gets 35psi hot oil pressure at 600rpm with Orileys 20w50 standard oil
The following 2 users liked this post by tech@WS6store:
blsnelling (01-17-2020), JF74chevelle (01-19-2020)
#65
You are correct, it is not a tractor engine. The engine did however come out of a big heavy duty truck with eight lug wheels that has been sold in countless countries all over the world so I will just carry on and trust that it was engineered for less than ideal operating conditions, assume it can handle a battlefield style crank swap, and continue to let it eat. To me, the Fact that I can make the power my way and take down some high dollar stuff at the dragstrip doing things my way is worth more than anything else. I've already put over 100 hours on it and it's still quiet as a mouse. 20w50 is also usually half or even one third of the price of the other weight oils at the store because nothing is made anymore that calls for it so I save a lot on oil changes. I've still got a long way to go before I spend $1000 on this engine lol
#66
Some of us folks that have been playing with These things since they were new saved all our books and did our homework showing just how tough these powerplants actually are, check out that minimum oil pressure!
#67
LS1Tech Premium Sponsor
It also holds in alot more heat and can cause other issues. Its a bandaid. And not a very good one at that. You can definitely clog up rings with it also. Especially the low tension oil rings.
It doesnt matter what it came out of gm never recommends above 10/30 for any ls engine and mostly does 5/30 for a good reason.
The following users liked this post:
G Atsma (01-17-2020)
#69
I used to say that **** to people before I finished College way back when I was just a "parts changer" working in crappy garages, truck stops, and body shops. Before that I was a heavy wheel Mechanic in the Army. I thought I was the greatest wrench ever, but then worked on my Masters ( after a Bachelor of Science in Psychology) at an engineering school, the most prominent in Missouri ( I have turned down teaching jobs since) I realized there that everyone who thinks they are the best car, engine, enthusiast, whatever, is just regurgitating the same **** they read in whatever magazine or site they like best and they never take any risks or try anything outside of what they digest from that and there's always a chance any build will break anyways when you do something like this yourself, it's hotroding. I've got 500 miles on it this one already and it's running Awesome, I'm really excited to see what kind of MPH it will throw up at the Dragstrip too! deliver pizza with this car part time for weed and vacation $ when there is less than 6" of snow on the ground so get over it, that goes for you to WS6STORE, I'd rather have no posts in my thread at all then more negative bullshit
The following 2 users liked this post by stockA4:
Homer_Simpson (09-06-2022), Rickys2003svt.cobra (04-30-2020)
#70
I for one applaud your 6 liter torque monster. I threw as little money as possible to get my '01 Camaro deep into the 13s at Fontana Autoclub and it has been a blast. The 2 major mods on my LS1 car are the 799 home ported heads and HP Tuners which puts me right back in the game with modern muscle cars. Well done stockA4.
#71
#72
#73
Not gonna argue about how well it does with 20/50 oil. Fact is, it would do better with 5/30 or 10/30. GM designed those truck engines sold in countless countries to run longest and most effectively with those oils. You are not doing the engine any favors using 20/50.
#75
No ones being negative here. In fact a lot of times when we (myself included) try to help you, you get offended and say stuff like this. Not sure why you started this thread to start with on a public forum, and not expect folks with actual knowledge to jump in and try to help you out, knowing you don’t want any advice to start with. You could actually learn something here on Tech if you’d just listen and stop barking back at folks.
G Atsma (01-19-2020)
#76
#77
I think his point is to show that there is more than one way to be successful with a build. With my Nova I rebuilt the 350 the right way by going 0.040 over flat top pistons, new bearings, assembly lube, prime the oil pump, etc. Then for my Camaro with 200k miles it's about trying different things such as torquing my head bolts to 55 lbs-ft with the original bolts, taking out the back seats and spare tire, and so on. I'm after bang for my buck and it's going well so far.
#78
#80
My budget engine has already paid for itself as I've put almost 3000 miles on it already delivering pizza with it. It runs great, like insanely great there's so much torque it makes me think I should be looking to swap my 2.73's for 2.41's haha. I have to pinch myself Everytime I drive it because it's so awesome I don't believe it myself. I do this **** because people should know that they can take a couple of these engines broken and just bolt themselves together one good one for no money at all and have something that goes
