Had to go 0.065 over LQ4 6.0 block =11:1cr 376" for less than $1000 all day build
Old 03-02-2020, 04:26 PM
  #121
TimsLS1's Avatar
Quote by Jayssz28
The bearings are pressure fed.
I said twice I was referring to the rod bearings which are splash fed,
The 5w is the cold start protection when the oil is at its thickest before in thins with heat, while the oil is heating up to operating temp it still needs to replenish all the bearings continually with oil it would be risky to rely on residual oil from the last heat cycle to do this.
There is a lot of science that goes into oil specs, don't mess with it if you want to get the best out of your engine. 20w-50w deviates greatly from the correct weight for cold start protection.
Old 03-02-2020, 04:28 PM
  #122
TimsLS1's Avatar
G Atsma
Is really respected here by me and a lot of others.
The following 2 users liked this post by TimsLS1:
G Atsma (03-02-2020), JinglingBaby (03-12-2020)
Old 03-02-2020, 04:35 PM
  #123
TimsLS1's Avatar
Your a bully !
I'm not sure what this has to do with Christ, please spell his name with a Capital C.
The following users liked this post:
  #124
Received 3,148 Likes on 2,455 Posts
Originally Posted by TimsLS1
Quote
Actually they ARE pressure fed thru passages in the crank to the rod throws. Older engines (Chevy six, for one) had scoops on the bottom of the rods to catch a squirt of oil from nozzles on the side of the block. Otherwise it would be fairly difficult to oil a rod bearing via splash. I hope this clarifies it for you.
Old 03-02-2020, 04:36 PM
  #125
Jays_SSZ28's Avatar
Quote by Jayssz28
Maybe G Atsma can kindly explain to you what the hole in the crank journal where the connecting rod goes is for.
Old 03-02-2020, 04:37 PM
  #126
stockA4's Avatar
I'll take something for my pain, sorry G. Tim don't worry I'm testing in St Louis were it gets very cold. You shouldn't worry about my rod bearings though they are already worn funny from the 4.8 they used to live in. What's really exciting is how well the old lifters pump at low RPM with the thicker stuff, there's a reason Valvoline makes 20w50vr1
Old 03-02-2020, 04:39 PM
  #127
Jays_SSZ28's Avatar
Your a bully !
Please use proper grammar. It's you're.
Old 03-02-2020, 04:40 PM
  #128
TimsLS1's Avatar
Quote
Ok my mistake and I apologise for posting something incorrect.
But you guys should still use the correct oil, the protection at cold temp is really important, I know it depends on your climate.
Old 03-02-2020, 05:04 PM
  #129
TimsLS1's Avatar
A photo of my rod bearings, they had no holes like the mains, so I assumed they were splash fed.
Old 03-02-2020, 05:13 PM
  #130
The rod bearings would have no holes, being fed thru the journal, and being "the end of the line", the oil just spews out the sides of the bearing/journal interface.
The crank bearing holes are because the oil is fed from the block thru the bearing to the crank, the opposite of the rod bearing.
Old 03-02-2020, 05:25 PM
  #131
TimsLS1's Avatar
Thanks Mate, I understand, Im lucky my birds didn't put holes in them for more lubrication !!!
Old 03-02-2020, 06:03 PM
  #132
Any time, my friend! Lovely birds, by the way!
Old 03-02-2020, 11:28 PM
  #133
stockA4's Avatar
You guys better be talking about Fbodys, specifically 4th gens if you mention Birds in my thread again!!!
Old 03-02-2020, 11:38 PM
  #134
"Your" thread?? Right.... sieg heil.....
Old 03-02-2020, 11:45 PM
  #135
stockA4's Avatar
Keep it up and you'll never get an idle video lol
Old 03-03-2020, 07:54 AM
  #136
blsnelling's Avatar
Wow, just wow.
The following 2 users liked this post by blsnelling:
EddieK (03-03-2020), G Atsma (03-03-2020)
Old 03-03-2020, 10:33 AM
  #137
EddieK's Avatar
Originally Posted by blsnelling
Wow, just wow.
My thoughts exactly. Some people are just obnoxious ******** and they go through life wondering why nobody likes them.
The following 4 users liked this post by EddieK:
00pooterSS (03-03-2020), 99 Black Bird T/A (03-03-2020), G Atsma (03-03-2020), JinglingBaby (03-12-2020)
Old 03-03-2020, 11:33 AM
  #138
Jays_SSZ28's Avatar
Old 03-03-2020, 04:28 PM
  #139
00pooterSS's Avatar
Originally Posted by Jays_SSZ28
I don't have a psychology degree like A4 does, but I don't need one to be able to tell you really ride A4's nuts
Before you bro out on me, keep this in mind
Again, I'll refer to the days of before the internet.
Why are people so sensitive these days? I'm typing facts (things that have happened to me) How do you get "rude" out of words on a screen?
Personally I'd rather talk to someone whose blunt and to the point rather than some jerkoff thats just there to take your money and kisses your *** with fakeness..
The following 2 users liked this post by 00pooterSS:
99 Black Bird T/A (03-03-2020), EddieK (03-03-2020)
Old 03-03-2020, 05:55 PM
  #140
TimsLS1's Avatar
I like stockA4 s thread a lot, Its great to see someone who can do it like he has and get a good result but I dont like the way the thread degenerated either.
Quote:
"really exciting is how well the old lifters pump at low RPM with the thicker stuff, there's a reason Valvoline makes 20w50vr1"
The 20w50VR1 you mention is a racing oil, it would likely be bad for lifters long term as it has very little cleaning ability for sludge removal and deposits compaired to a conventional oil for road use. Sludge build up and deposits are one of the major causes of lifter failure.
Some lifters like for example the Hylift 2148 SE have tolerances of only 1/30 the thickness of a human hair.
If you think about it makes sence a racing engine has much shorter service intervals between oil changes and it often isn't very long before they pulled down for refleshing and steam cleaned so an oils cleaning ability isn't as big of a consideration if at all.
It's best to use an oil that is application specific there is a lot of science that goes into it. All the racing oils I have checked have low levels of detergent. Most of the racing oils are not legal for road use although the VR1 in link here is an exception and is. Again they are application specific!
https://www.valvoline.com/about-us/faq/racing-oil-faq
Quick Reply: Had to go 0.065 over LQ4 6.0 block =11:1cr 376" for less than $1000 all day build
