Lifter preload?
Old Jul 3, 2019 | 01:49 PM
TableLeg's Avatar
Default Lifter preload?
I have a GM 5.3 L33 from a Silverado and have a Comp 212/218 Hi-Lift cam to go in, I plan to keep the standard lifters as they looked fine.
I have read numerous different pre load suggestions so if somebody can please clarify what I should be aiming for that would be great.
I have the standard pushrods at the moment but I plan to use heavier duty ones once I calculated the lengths required. I also already have a Comp Cams pushrod length adjustable tool.
So what pre load should I be aiming for?
Thanks in advance.
Old Jul 3, 2019 | 03:04 PM
Your going to hear opinions varying anywhere from .060” to .120” preload.
I shoot for .075”ish with LS7 lifters, and it’s fairly quiet. I’ve seen guys set it at .100” and they drive it like a loaner.
Old Jul 3, 2019 | 03:06 PM
Ls7colorado's Avatar
With a small cam like that I would just use stock pushrods, tighten down and go.
But of course you should "ALWAYS" check for proper pushrod length............................................ ......................
Old Jul 4, 2019 | 06:59 AM
TableLeg's Avatar
Thumbs up
Thanks for the reply
You're exactly right, so many different opinions!
I don't know if the lifters in my engine would be the same as the LS7 ones or not. My engine is from a 2005.
I'll aim for your suggested 0.075" preload.
Old Jul 4, 2019 | 07:01 AM
TableLeg's Avatar
Thanks for this
So you don't think it is worth upgrading the pushrods?
If not, I may get lucky with the standard pushrod lengths being the same as what I need. Of course I guess though if I do need new rods (different length) then it makes sense to use uprated ones?
Old Jul 4, 2019 | 09:38 AM
MplSS's Avatar
Don't forget about valvesprings, if yours are still stock, you should replace them with at least 918's.
Old Jul 4, 2019 | 09:53 AM
TableLeg's Avatar
Thanks for that, I already changed them to Pac 1211x springs.
Old Jul 4, 2019 | 10:33 AM
Upgrading pushrods is never a bad idea, and here just a nice set of chromoly aftermarket ones from a reputable source will be plenty for your setup. That cam is well proven and should do you well.
Old Jul 4, 2019 | 10:49 AM
Well with those stiff springs I probably wouldnt risk using the stock pushrods for $100 you can get some nice ones
Just curious but what is this going into?
Old Jul 4, 2019 | 10:54 AM
TableLeg's Avatar
I'm 5 years into my build, hopefuly have it finished this year!
Old Jul 4, 2019 | 10:55 AM
TableLeg's Avatar
Thanks ALL,
I think for the low cost I'll get some uprated pushrods.
Old Jul 4, 2019 | 11:43 AM
01CamaroSSTx's Avatar
Now that's my kind of engine bay right there!
Old Jul 4, 2019 | 12:31 PM
Is that a Brunton Stalker? If not which one? VERY cool car!
Old Jul 4, 2019 | 01:18 PM
wannafbody's Avatar
Exocet?
Old Jul 4, 2019 | 01:40 PM
WOW glad I asked that thing is gonna be a rocket!
Old Jul 4, 2019 | 02:50 PM
TableLeg's Avatar
Originally Posted by TableLeg
Thanks ALL,
Any recommendations on pushrod makes? Comp, Brian Tooley, Cam motion, others?
Also 5/16" or 3/8" ?
Old Jul 4, 2019 | 02:59 PM
TableLeg's Avatar
Thanks Guys,
It's a Westfield Sportscar Kit. They did a model many years ago that used a UK 3.5L Rover V8 (originally a Buick V8 I believe).
https://westfield-sportscars.co.uk/
I wanted to build a V8 this time (it's my 3rd one, first was 4 pot NA, 2nd was 4 pot Cosworth Turbo),
Old Jul 4, 2019 | 03:05 PM
http://www.ws6project.com/user_stor/...cd45bo8tle6nk5
these are the ones ive been using, so far so good, running Tsp dual springs and a MUCH larger cam than yours, and spin it passed 7000 regularly...
Old Jul 4, 2019 | 03:07 PM
TableLeg's Avatar
Another shot of the engine bay.
I'm really happy that I've been able to squeeze the engine under the bonnet without having any lumps or bumps to give it away. Only the 2x external side pipes
Old Jul 4, 2019 | 03:09 PM
looks Awesome!
