Rod Bearing Clearance Question...
.00185
.00205
.00200
.00205
.00185
.00195
.00200
.00195
The main crank journal clearances were .002 +.0004/-.0000
Based on those numbers, I'm going to be running 5W20 oil through it.
I just wanted to make sure the clearances were't too tight as this is my first LS motor build (going in my 68 Camaro). Really taking my time with it to make sure I don't miss anything.
Hydraulic pressure is pretty magical, so for high power tight tolerance I'd go with a GOOD micrometer and bore gauge and measure several places each to check fore oval journals and rod bores.
(This is why my question above..
) Trending Topics
