Replaced cam sensor still not right?
Also make sure the grounds are tight on the back side of the drivers cylinder head.
Unplug and reconnect the PCM connectors a few times. You wouldn't believe how many issues I've fixed doing only that in my career as a tech. Connections get corroded over time, unplugging and replugging scrapes the pins and sockets and can fix a poor connection.
Go from there and let us know how it's going.
Also, every once in a while you come across a code that the factory just got wrong. I had a hyundai come in with a fuel temp sensor code error the other day and the problem was the coolant temp sensor on the engine. We found that out after replacing the fuel temp sensor in the fuel tank.
The problem ended up being that the programming used the coolant temp as a check for the fuel temp, after the car sat over night the temps were both supposed to be ambient temp and if there was a disparity then one of the sensors was wrong. That is correct. What they forgot to do at the factory with the programming was to allow the possibility that the coolant temp sensor could be wrong. For whatever reason they just wrote it to where if there was a difference in temp it threw a code for the fuel temp sensor.
Sorry for writing a book, I'm a tech and I see stuff like this sometimes and it's aggravating. On 07-13 GM trucks, they throw codes for the canister vent valve being bad when in fact it works, but the pressure sensor is stuck. Since the system doesn't see a pressure change, it assumes the vent valve isn't operating. Sometimes they just don't think of every possible scenario, and that's understandable.
Sounds like you've found that type of thing with the cam code on these cars.
This usually always happens within the first 5 minutes of the cruise and lasts only a minute or two until the needle finds it's place again and the car drives normally. If I were to do a quick pull at this point the engine will shut off at high RPM. While I had the intake manifold off I inspected that 6" to 8" of exposed wiring to check for breaks or corrosion and it looked okay.
My thought at this point is an ECU issue. The motor is stock besides a lid and HP tune done at reputable race shop.
