LIFTERS, having a hard time finding good ones
Old Feb 10, 2020 | 10:07 AM
  #81
SLP IROC-Z's Avatar
Oh no! Your not talking about the TSP polished 660 spring kit that comes with their integrated valve stem seal?
those are the ones.
Old Feb 10, 2020 | 10:09 AM
  #82
SLP IROC-Z's Avatar
You were shifting at 7800-8100 or something weren't you?
god no lol shift light was set at 7100.
Old Feb 10, 2020 | 10:32 AM
  #83
ddnspider's Avatar
Thats weird, I thought you were in the 8k range in your build thread. Must have you mixed with someone else.
Old Feb 10, 2020 | 10:45 AM
  #84
SLP IROC-Z's Avatar
the springs i have now will be safe at those rpms but i have no intention of running it that high. its more of an insurance policy incase of a missed shift or mechanical over rev.
Old Feb 10, 2020 | 12:18 PM
  #85
omc8's Avatar
Originally Posted by blsnelling
JAMSI has them for $189.99.
Ooops, lol. $229.99.
The $189 price is for Set of 12 v6 ........... Price for a full set 16 V8 , 2148se from that vendor is $256 basically they are about $16 each regardless which way you buy !
Old Feb 10, 2020 | 01:14 PM
  #86
01CamaroSSTx's Avatar
Did you go with BTR this time?
Old Feb 10, 2020 | 01:16 PM
  #87
SLP IROC-Z's Avatar
Pac 1208x
Old Feb 10, 2020 | 01:25 PM
  #88
Kfxguy's Avatar
Ok. I never bought lifters last time I had the engine apart. I was so confused and just reused my old ones. I really wanted ls7 or the delphi's, but I cant find any and the only Gm ones I can find for a decent price, are not gm packaged and are bulk packed and claim to be genuine gm lifters. I dont trust that. So i consulted a good friend of mine that builds these engines for a living. I didnt even mention the elgin, but i asked about a good affordable lifter and his reply was stay away from elgin lifters and use the hylifts if i cant get genuine ls7 units.....My local engiine parts warehouse has those for $140. So as of now, thats what i decided on. That could change if i find something else before thursday when I got pick them up.
Old Feb 10, 2020 | 02:13 PM
  #89
ddnspider's Avatar
7k+ shift points here with boost.....WS6 store bulk packaged LS7 lifters, no issues.
Old Feb 10, 2020 | 02:42 PM
  #90
Jays_SSZ28's Avatar
There are four companies manufacturing ls7 lifters.
And probably five times that in brand names on these same lifters.
Old Feb 10, 2020 | 03:58 PM
  #91
jayyyw's Avatar
I had good luck with the drop-in Morel lifters. They are about $200. Took them to 7800rpms regularly.
Old Feb 10, 2020 | 05:18 PM
  #92
NighthawkWS6's Avatar
Im running michigan motorsports ls7 lifters and there doing just fine.
Old Feb 10, 2020 | 07:11 PM
  #93
I'll stick to using link bars in an effort to reduce the risk of spinning a lifter.
Old Feb 11, 2020 | 08:11 AM
  #94
Cstraub's Avatar
Originally Posted by TimsLS1
Quote "That thread was for 2014. Things haven’t changed in 5 years?"
I don't know if they have changed since then, 20% for the Morels is high.
I wonder if engine oil carbon and sludge would effect the finer tolerances in a slow leak down lifter more that a standard one as engine oil contamination is recognised as a major cause of lifter failure? I have had success once with engine oil flush quietening my stock LS1 lifters a few years ago, there are also lifter free additives available. Makes me think clean oil is important​​​​​​ with lifters.
Returned Morel lifters for warranty inspection has never exceeded 1% of lifters sold. LS hyd. lifters shipped last year to board sponsors numbers 1626 sets. Returned for inspection was 14 sets of LS. Of the 14 sets......8 sets had debris in lifter...4 sets checked just fine, no issues...2 sets had a leak down issue and were replaced. This is documented data. Any mfg would take this return rate and RAVE about it.
Old Feb 11, 2020 | 09:17 AM
  #95
Bspeck82's Avatar
I found these...http://www.cammotion.com/lifters/ls1...cement-lifter/
https://www.tickperformance.com/gm-h...fters-for-ls7/
Old Feb 11, 2020 | 10:05 AM
  #96
Summitracing's Avatar
LS1Tech Sponsor
Hello there, the SUM-HTLSKIT LS7 Lifters, trays and bolt kits make our customers very happy and currently sell for $153.99.
__________________
800-230-3030
www.SummitRacing.com
Old Feb 11, 2020 | 11:18 AM
  #97
kinglt-1's Avatar
Morel 6504.
Old Feb 11, 2020 | 12:14 PM
  #98
RonSSNova's Avatar
Thanks Chris.
Old Feb 11, 2020 | 12:26 PM
  #99
SLOW SEDAN's Avatar
Does that only cover the "Morel" brand name specifically and not the brands they provide parts for like Lunati?
Old Feb 13, 2020 | 01:08 PM
  #100
Kfxguy's Avatar
Picked up hylift Johnsons today for $129 local. Had I not been in a hurry, I would have ordered some from summit or ws6store. they definitely look nicer than my factory ones. looks aint everything tho.
