LIFTERS, having a hard time finding good ones
Old May 24, 2020 | 10:30 AM
  #121
Bspeck82's Avatar
It's not hard to find a good lifter. GM makes decent lifters, Isky makes good lifters, morel makes good lifters, johnson makes good lifters, some cam manufacturers get their lifters from these companies and private label them like lunati/morel.
People here trying to save a buck getting lifters that dont even fit? Jesus christ are you kidding me? Go buy the right stuff and treat your car right or go buy a new factory car that's already fast. Smh.
Old May 24, 2020 | 04:58 PM
  #122
TimsLS1's Avatar
​​​​​​Quote
There are discussions on this happening with other brand lifters also in an LS engine, it depends primarily on the engine year and small variations rather than the lifters from what I have read.
The 2148 SE lifters and trays cost me $500 AUD not exactly cheap.
Quote
Do you know the recommended preload for those lifters with a iron block-aluminum heads?
.030 preload is standard for them mine varied from .025 to .045 pre load, the 2148 SE are an SBC lifter with iron block so should work well with your application, they are the only lifter around $230 USD designed for dual springs & 6500 + rpm suitable for an LS.
Old May 26, 2020 | 10:49 PM
  #123
wannafbody's Avatar
If the lifter is too tight for the block, I'd suspect the block is slightly off vs the lifter being off. Lots of these engines have slightly out of round cylinder bores. If GM couldn't get a big hole round I doubt they could get a small hole round either.
Old May 26, 2020 | 10:56 PM
  #124
TimsLS1's Avatar
Yes thats what I thought, for me to have removed enough for it to fit well with what I did the difference must have been microscopic.
Old Oct 27, 2020 | 10:16 AM
  #125
mike lm7's Avatar
Default Michigan motorsports ls7 lifters
Originally Posted by NighthawkWS6
Im running michigan motorsports ls7 lifters and there doing just fine.
I just built a fresh 5.3 LM7 .30 over speedpro dished pistons 706 heads Howard's rattler cam. And used Michigan motorsports ls7 lifters, trays, pushrods ,btr truion upgrade kit. Kinda getting scared of all these posts on failed lifters. Any suggestions?
how are yours doing now?
