LIFTERS, having a hard time finding good ones
Old Feb 13, 2020 | 01:21 PM
  #101
Metalchipper's Avatar
Talking Keep us posted!
Originally Posted by Kfxguy
Picked up hylift Johnsons today for $129 local. Had I not been in a hurry, I would have ordered some from summit or ws6store. they definitely look nicer than my factory ones. looks aint everything tho.
Thanks for the update. Please keep us posted.
I am planning on rebuilding my 5.3 this summer so this is of interest for me.
Old Feb 13, 2020 | 08:42 PM
  #102
Kfxguy's Avatar
I had more time this evening to look at them. Still the same locking clip as a stock lifter but the hole isn’t lined up with the flat on the body and the overall machining looks much much nicer than my factory lifters. They are soaking right now. I went to the gym and I’ll probably put them in tonight or tomorrow night.
Old Feb 14, 2020 | 09:51 AM
  #103
omc8's Avatar
Which ones did you get , B2148 with the trays . What are you going set preload at ?
Old Feb 17, 2020 | 08:56 PM
  #104
Fah Cue's Avatar
Originally Posted by blsnelling
I'm torn on this as well. I'm getting ready to put a 233/240 cam with .660" PAC springs on ported 243 heads in my '02 TA. The car only has 21K miles on it. I asked TSP if I needed to replace my lifters and they replied no. Never the less, I'm still worried about it. I don't ever want to have to pull these heads again. Should I eliminate doubt and "waste" $400 on a set of Johnson 2110 lifters?
Heres my two cents.
I pulled my engine apart to freshen it up and change rod bolts. Last season I spun it to 7200, and this year will be no different. So I did research on the drop in lifter options and was just about settled on the morels. Then I heard about these 2110s. Then I found out I live 8 mins from thier shop. So I go down there a couple weeks ago. Randy gave me a tour of the shop, showed me the metallurgy data, showed me testing data from the copo development and a set of lifters from Ruby's second engine lol.
I was sold.
Old Feb 17, 2020 | 10:08 PM
  #105
blsnelling's Avatar
I just finished my build using the Hylift-Johnson 2148SE lifters. These are a "Slow Design" and have "Direct Shot" oiling for the roller bearings in them. The valve train is silent, and was even on initial startup.
Johnson 2148SE Lifters
They're very affordable for a high performance US made lifter, LINK
Old Feb 17, 2020 | 10:22 PM
  #106
Fah Cue's Avatar
I was looking at those as well, my concern was more about RPM and an aggressive cam lobe. Those just didn't give me much confidence to handle 7200+ and 420lbs. I'm sure they would, hell my stockers lived. But I just don't want to play games with it. I'm glad they worked out for you!
Old Feb 17, 2020 | 10:51 PM
  #107
TimsLS1's Avatar
Thanks blsnelling, nice to hear it went well. I havent used mine yet. Don't really need them with my mild set up, oh well, I'll use them anyway.
Old Feb 17, 2020 | 11:34 PM
  #108
CattleAc's Avatar
So the 2148SE's are drop ins for the LS platform?
Old Feb 18, 2020 | 12:09 AM
  #109
TimsLS1's Avatar
Yes they are drop ins for the LS platform, a good performance lifter, actually meant for dual springs, not too many know about them.
Old Feb 18, 2020 | 09:07 AM
  #110
Sdmodified's Avatar
At what point is it recommended to switch to a slow leak-down lifter like these? The TSP duel spring kit that comes with their cam kits use PAC springs that have 415lbs of open spring pressure. Would a cam kit with these spring benefit from these Hylift-Johnsons SEs over a drop in set such as the lower end Hylifts or Morrels?
Old Feb 18, 2020 | 09:13 AM
  #111
SLP IROC-Z's Avatar
those springs and tsp lobes wont support enough rpms to need a lifter like that
Old Feb 18, 2020 | 09:27 AM
  #112
Sdmodified's Avatar
Gotcha. Thanks!
Probably still going Morrel drop-ins then.
Old Feb 18, 2020 | 09:34 AM
  #113
SLP IROC-Z's Avatar
Gotcha. Thanks!
Depending on what you have for a cam and how high you want to rev it you may want to upgrade springs. I had a terrible experience with those .660 pac/tsp springs in my car with tsp cam. I wouldn't push it past 6800-7000 to be safe.
Old Feb 18, 2020 | 10:02 AM
  #114
TimsLS1's Avatar
I remember reading that LS7 lifters are rated to 360 lbs max spring pressure which would mean they are not suitable for almost all dual spring set ups, (re: many have used them successfully with duals) It was that info which was the deciding factor for me in going to the 2148 SE slow lifter I wish I could find the link, it may have been on the Summit Racing website.
Old Feb 18, 2020 | 10:18 AM
  #115
SLP IROC-Z's Avatar
they may be rated for 360# but you have to consider the open spring is rated at 415# max lift, it will be lower than that with cams at less than .660 lift.
Old Feb 18, 2020 | 01:52 PM
  #116
TimsLS1's Avatar
Yes I wasn't sure how much that was a factor but thanks it's important to remember.
If I had a cam that peaked over 6000 rpm with duals I'd run the slow lifter design because too soft a lifter can rob power the same or perhaps more as too thin a pushrod can.
I don't need duals I just run them for safety, the place I purchased them from said there are people running there dual PAC springs on stock engines
Old Feb 18, 2020 | 06:11 PM
  #117
blsnelling's Avatar
That's exactly what they're designed for.
Yes.
A lot of guys do it, but LS7 lifters are not designed for dual springs and high RPMs. These 2148SE lifters are. Regular H-J 2148s and Morrels are a standard lifters like the LS7.
Old May 23, 2020 | 07:54 PM
  #118
TimsLS1's Avatar
My Hylift Johnson 2148 SE are also quiet and seem to be working well except strangely one of them would not fit inside the bore, I lightly abraded it with some 800 grit rotating it about 20 times in my hand and this tiny removal of material was enough for it to fit smoothly in the bore, I had to do this with two of them.
Old May 24, 2020 | 08:25 AM
  #119
Default Better than too loose
Thanks for the information - that is good news, better a little over sized than too loose. I have some new Hylift Johnson 2148 SE for my upcoming rebuild.
Do you know the recommended preload for those lifters with a iron block-aluminum heads?
Also how much valve spring pressure are you running?
I agree that the stock lifters just can not handle more spring than stock. And if that is true, it would interesting to know how much actual valve lift is lost and the lost performance due to the increased clearance.
Old May 24, 2020 | 09:19 AM
  #120
jerflash's Avatar
I can't find the Johnson 2110 lifters anywhere in stock. I had a ls7 lifter fail and cause a full rebuild. Lifters did not turn in the tray, the roller bearing failed and wiped the cam.
Never using those again and want a lifter that will be up to the task. I need something asap... Need to get this motor back together. Interested in the Hylift Johnson 2148 SE lifters now. Are they they the same height and and preload spec as ls7s? Just need all the info before going forward.
Thanks!
