Trunion "Upgrade" Failure
Old 12-23-2019, 04:58 PM
  #121
Received 3,397 Likes on 2,099 Posts
Originally Posted by Johnny_M
if you're talking about the BSR shaft system. They require oil pressure from the oiling system. Still not roller tip.
I didn’t realize that the pressurized oiling was required. I thought I’d read it was optional.
Old 12-23-2019, 05:13 PM
  #122
Johnny_M's Avatar
yes it optional. They won't last long without it though.
Old 12-23-2019, 05:18 PM
  #123
Johnny_M's Avatar
Originally Posted by cujo18
Comp trunion 12,000 miles, cam was cam motion 244/256 620.595. I'm going with the che kit.
CHE kit with roller tip rockers. You have over .600 lift. The stock rockers lock up according to Kenny Duttweiller.
Old 12-24-2019, 12:08 AM
  #124
LS1Tech Premium Sponsor
tech@WS6store's Avatar
The comp shaft stock style rockers may "handle" up to .700 lift but they will still side load the valve and can cause improper wear.
The stock rockers dont lock up though. Thats somewhat an improper way to put it. Its an arc'd pad. If it were flat that could be an idea, but the only real issue for other wear is from an untrue pad or untrue alignment from the rocker bolt boss in the head, the rocker rail itself, or the rocker assy then the tip. OR the valve itself. Guide tilt etc. You can blame it on so much it becomes a "rabbit hole" issue.
The following users liked this post:
Johnny_M (12-24-2019)
Old 12-24-2019, 10:00 AM
  #125
ramairetransam's Avatar
off topic , what roller rockers then that wont cost a fortune .
Old 12-24-2019, 10:05 AM
  #126
Johnny_M's Avatar
TSP has 1.7 for $549 , Comp Ultra pro magnum in 1.8 only for $349
Old 12-24-2019, 12:33 PM
  #127
Omega Doom's Avatar
I ran a RPM cam 238/244 612/588 lift for 10 years with NO trunnion upgrade with NO issues
wannafbody (12-24-2019)
Old 12-24-2019, 02:32 PM
  #128
JimMueller's Avatar
Hmm, I installed rockers in this link, with the LS3 CHE options, back in April. I've put maybe put 4000 daily driver miles on the engine since then; .how soon/often do I need to check for wear? If I was nervous about them and switched to another rocker arm style (or back to my original rocker arms that I have in storage), then I think I may have a separate issue. I have the Johnson axle-oiling lifters, so would I potentially need different length pushrods if I changed lifters? It seems I've read that you don't even want to move existing rocker arms to different valves as it'll throw off the preload.
https://www.texas-speed.com/p-1088-t...m-package.aspx
Old 12-24-2019, 02:37 PM
  #129
Johnny_M's Avatar
Cut your oil filter open when you change the oil. You'll see the bronze man glitter in the the filter element when they start to wear.
Old 12-24-2019, 04:03 PM
  #130
bigsapper's Avatar
Any thoughts on these?
Summit Racing® Pro LS Upgraded Rocker Arms SUM-141556
Old 12-24-2019, 04:16 PM
  #131
sjsingle1's Avatar
ok......comp trunion upgrade bad......bronze is glitter in your oil.........WTF is the best option !!!!
Old 12-24-2019, 06:04 PM
  #132
Johnny_M's Avatar
If you are under .600 lift I would go with the ws6 store / rpm speed max effort rockers. Over .600 I would go with steel roller tip rockers. That's my prior experience. Opinions may differ.
Old 12-24-2019, 06:33 PM
  #133
sjsingle1's Avatar
did yella terra ever fix the breakage problem ? any other roller tip options ?
Old 12-24-2019, 06:41 PM
  #134
wannafbody's Avatar
I've read that roller tips are more unstable than stock rockers.
Old 12-24-2019, 10:36 PM
  #135
Any alum rocker is going to not only be heavier but also have a much shorter fatigue life vs steel and can still have deflection. Picture an adult sized playdough fun factory and thats how they make alum rocker arms. So any flaw in the material or process etc will show up in an entire batch BUT wont just show up only in one set as they are made in huge batches.
I cannot attest to how the comp cams rockers are made but the tsp are investment cast just like stock with some obvious strengthening of the areas for the tip etc.
They do require a shorter pushrod, which is good. They arent nearly as bulky as most other alum rocker and normally dont require any spacers or super thick gasket etc.
I haven't installed a set of the new comp cams sets so i cannot say anything there.
As far as the other guy changing from a johnson to a reg lifter you would need different pushrods. Likely .025 longer but i dont like to measure pushrods on paper. Its always best to measure on the engine.
Also, make sure you have the right spring for a roller rocker. Some have good pressure but might not be as stable with more weight on them due to design or material and dont recommend roller rockers with them. Always ask your spring provider there.
Old 12-25-2019, 10:58 AM
  #136
Johnny_M's Avatar
Steve, Dave and Dulcich did an episode on engine masters on roller tip rockers. I would disagree with what you've read after watching the dyno results.
Old 12-26-2019, 04:06 PM
  #137
dreadpirateroberts's Avatar
I was wondering what he meant when he kept saying "locked up."
What part of the rocker is he talking about?
The only lift limitation to the stock rocker arms i knew of previous to this was the shape of the tip, and as it went over a certian valve lift that it would no longer be centered on the tip of the valve stem. Thus, side loading the valve slightly. People still run them this way, though, so...
Old 12-26-2019, 04:11 PM
  #138
That brinelling wear is from constant repetitive motion over the same spot, exacerbated from lack of lubrication. Like what you would see in a worn out u-joint.
You never said what this guy meant when he said "locking up" over .600 or .630 lift. WTF does that even mean?
Old 12-26-2019, 04:12 PM
  #139
They wear as soon as you start using them. By design. The only thing this thread and others show is that such wear takes place over a much shorter period of time than advertised.
i would think any application that uses higher than the stock spring pressure and an aggressive cam lobe is going to put more stress on the rocker trunnion, regardless of the design of the trunnion.
Old 12-26-2019, 04:53 PM
  #140
LilJayV10's Avatar
It really depends on who the favorite is this week on LStech. Next week it will be different.
The following 2 users liked this post by LilJayV10:
Che70velle (12-26-2019), stngh8r (11-30-2020)
Quick Reply: Trunion "Upgrade" Failure
