Advise for Engine build LQ9
Old Dec 24, 2019 | 08:44 AM
  #61
Speedman87's Avatar
Often times, a broken spring means the valve hit the piston. Might need a valve also, but that’s easy peasy.
yes you’re correct. Didn’t see any “kiss” marks with the borescope. Passed the leak down test. Told the customer May be further damage. If it did bend a valve the truck will be getting an engine. Has 310k miles and leaks like a Sieve. Wishful thinking.......
