Advise for Engine build LQ9
Rick
I think I've heard more bad stories around here of engine trouble AFTER a rebuild than simply installing Mr Goodwrench's good work and running it.
Rick
The ONLY time I would recommend it would be if something was known to be wrong with it.
BUT, even then if your goal is under 500RWHP I would just get another clean junkyard shortblock.
Only time it makes sense financially is if your going to be boosting the engine and in need of some forged internals.
And if thats not enough ......why in the world would you replace the pistons with the same thing that is already in there for $70 EACH!!!???? and rings for $40 each?????!!!! Thats ludicrous!
The bottom end has never been touched other than timing chain, gears ....oil pump ....
If a little 1.8 liter with a turbo can handle that kind of beating, an LS certainly can.
These engines don’t rebuild cheap. Gaskets are expensive. Bearings are expensive. Piston kits are expensive. Send a PM to WS6Store here on Tech and tell them your thoughts. They will give you rock bottom pricing on a complete rebuild kit. Then get an estimate from the machine shop of your choice. You likely can buy 2 or 3 LQ9’s for the price of a rebuild, but you don’t know what you’ve got til you start it up. If you rebuild it, and measure everything as you assemble, you know exactly what you have.
I love a Monte SS. Post pics!
Just picked it up a week ago. The fun begins!!! Did an LS Swap in a 70 Chevelle for a customer. In love with the car but that swap left a bad taste in my mouth. Want to do mines right. He went with a Bone stock LQ4 and a bone stock 4l80. Turned out to be a mess because the owner was a cheap ***. Showing up with sub par parts other than what i suggested for the build, didn't want to paint the engine, didn't want to clean up and paint the engine bay, didn't even want to reseal the engine. Running the car with around with the original rear end with 2.56 gears and drum brakes in the front. complete mess
