New AFR Budget LS Head
I would love to see the specs on these, especially on whether they can be used on the 3.78" bore 4.8/5.3.
The following 3 users liked this post by LilJayV10:
Wouldin' the new Promaxx small bore LS3 heads be a better option. They state their as cast square ports will out flow most all ported cathedral heads. Bolt on a cheap LS3 intake and rock.
https://ls1tech.com/forums/generatio...ls3-heads.html
Yes that's my point ! It will not only effect the other as cast competition , but CNC on oem castings and aftermarket alike . And on the resale side of things Do you think a guy that has a set of lightly used $2500 heads is going to be able to sell them for $1500 to $1800 when you can buy these afr for close to $1000
They are really a great upgrade on engines that were originally running 317 heads. I was kind of shocked to see the 706/862 heads did so well on 6.0, They may not flow as well as the 243's but the bump in compression they are worth apparently makes up for the difference in airflow over the 799/243 heads. Aftermarket heads will typically flow better in the lower RPM range while still not giving up power at the top end, Basically they produce a better average torque and HP. It also helps that you can get heads better suited for the larger engines.
The following users liked this post:
00pooterSS (12-30-2019)
#32
#34
I did a 2.030 60ft with street tire and just sharing that so others keep in mind that high dollar street slicks are not needed for good launches. I did a 1.875 60ft in a buddies C7 and ran a mid 12 and that car is on the pricey side. Sub 2.0 60fts come at a price.
#35
If someone has a basically stock engine then ported stock heads work great but most aftermarket heads will still make more power...probably not enough to justify the $2,000+ price tag. Where they really shine is on an engine that was built to take advantage of them, Instead of seeing 25-30hp increase over a stock ported head they may make 70+ more hp and in many cases it's well above that. Big cubic inch or boosted engines can use all the flow advantage they offer and they become cost effective. I think these budget AFR heads will fall in between stock heads and the high dollar heads. In other words, Rather than someone paying to have stock heads cnc ported and installing better valve springs/retainers, You'll be able to buy these ready to bolt on for about the same cost. I can't wait to see what they are offering for the low price.
BCNUL8R (12-28-2019)
