Cam grind
Old Jan 16, 2020 | 03:24 PM
blueracer15's Avatar
Default Cam grind
Friend has a spare can I was looking to buy off him
220/226 .620/.620 114+4
Turbo 5.3
CNC 243
Th400
3000Lbs
Will this be good fit for street driving?
Did the math and it shows to have -5 overlap.
And of course will it chop?
Old Jan 16, 2020 | 07:52 PM
Turbo 5.3
CNC 243
Th400
3000Lbs
Should be fine on the street, with just enough lope to let the riffraff know it ain't stock. Plus, the 4deg. advance will close the intake earlier giving a little more oomph off the line.
Normally you don't want much cam with a turbo, but this should be fine.
Old Jan 17, 2020 | 05:56 AM
blsnelling's Avatar
No, that's not going to chop.
Old Jan 17, 2020 | 11:01 AM
But it WILL NOT sound stock.
Old Jan 17, 2020 | 12:48 PM
I see most people running the BTR stage 2 (226/231 .605/598 113+4)
figured this would be something a little less.
I know lift is higher but with duration being lower thought it would be suitable
how low would you go for something that will see the street more often
Old Jan 17, 2020 | 02:55 PM
I think with the turbo doing most of the work, this cam will give you a little better drivability than a more ragged one.
Old Jan 17, 2020 | 07:16 PM
what about
212/218 .600/.600 112 +4
with the +4 and it beign a small cam i think it wouldnt have much top end ?
Vendor has this on sale in their clearance items
i think i would retard it 2-4 degrees so it would be closer to straight up?
Old Jan 17, 2020 | 08:20 PM
what about
Likely THE most common LS grind in existence. With the turbo, top end is not a concern.
