Boosting LS1/LS6
Old Feb 2, 2020 | 08:46 AM
wayland1985's Avatar
Default Boosting LS1/LS6
I’m considering some power upgrades to my 01 Camaro.
I’ve always been a proponent of NA, but the thought of boost is growing on me: especially the Huron Speed kits.
I know lots of guys go with Iron Blocks, but I’m also concerned about weight/heat dissipation (keeping the AC).
This isn’t a race car... it’s a weekend cruiser 99% of the time.
This all being said: can the aluminum block LS1 or LS6 be built to reliably handle more than the 10PSI of boost that the stock bottom end typically can’t? It seems most say the rods are the weak link.
Or should I be starting with a new block altogether?
Old Feb 2, 2020 | 09:49 AM
sxc Z28's Avatar
Lots of ways to skin this cat. For the most part it comes down to the tuners capabilities. A meth injection kit will help if you stay with the stock block. You can even throw some gen4 rods and pistons in with boost gapped rings and go quite a bit over 10lbs I would say. That’s how I’d do it personally because I’d want the benefits of aluminum. Others would likely sell the ls1 and get a jy engine which is proven for sure just different ways to do it I guess. Just thought I’d comment because I have contemplated the same thing before. Good luck
Old Feb 2, 2020 | 11:11 AM
ddnspider's Avatar
You need to start with goals. Don't think in terms of a specific psi. That will determine what you can and can't do. I'm currently running 10 psi and about to turn it up on a rebuilt LS6 with stock crank, stock rods, and hyperutectic pistons.
Old Feb 2, 2020 | 11:56 AM
SLP IROC-Z's Avatar
Gen 4 rods and pistons or a gen 4 motor and you could make some serious steam reliably
Old Feb 2, 2020 | 02:36 PM
The iron does seem to be a much more stout option; but without researching too much into it, I feel aluminum is the better option for a couple reasons: first being weight (turbos or supercharger adds weight already....) second being heat dissipation (again, this is my weekend car: I want to have AC in the 90 degree weather!
Goals would be reliability, street ability, and fun. I can’t say I’d be aiming for a particular number at the track... and I can’t say that I’m building a particular race car.
I’m looking for a car that I can take places without beating myself (or my wife) up in. I don’t want to be lurching while I try to find a parking space at low speed.
But I do want something that’s still nimble and fun around the corners.... and quick enough to maybe give newer cars a run for their money (hellcats, corvettes, or what-have-you) should I find myself beside one.
For a handful of reasons, I’d like to keep the matching motor with the car: so I’ll have to look into this more.
At the same time, I’m starting to read about other blocks: like an LSA... which has its own appeal.
I have relatively new new TFS heads installed on the factory block. The build is one I did with my father: so it has sentimental value in itself: ideally I’d like to keep the motor and heads in the car, but not if it’ll blow up when I try to get some more power out of it!
Old Feb 2, 2020 | 02:40 PM
ddnspider's Avatar
Sounds like modest goals. Something in the mid-5xxx whp range would work and life on your stock motor. Do you know what your compression is with those heads? Ideally you could swap heads to stock 317's for cheap or something ported with larger cc chambers and throw on a turbo kit. Keep boost reasonable and perhaps consider a meth kit for cushion and it should live a long time.
Old Feb 3, 2020 | 08:06 PM
Ls7colorado's Avatar
Summit forged rods and pistons..... simple as that. Would be good for way more than you wanna push through it
Old Feb 10, 2020 | 02:53 AM
NighthawkWS6's Avatar
I had a 99 z28 on 16 psi and nitrous stock bottom end ls1. Made 900 to the tire and it lived for almost 10 years. No meth injection or anything. It's all in the tune. AMD this car had the absolute **** ran out of it. And was a daily driver for 6 of those 10 years. Finally took a **** at 207k. Everything was installed at around 80k and it lasted that long. It made 1000mile plus trips.
Old Feb 10, 2020 | 05:54 AM
ddnspider's Avatar
Vids/slips/pics of a stock bottom end ls1 made 900whp for a decade please.
Old Feb 10, 2020 | 07:46 AM
AwesomeAuto's Avatar
He isn't off to a very good start here.
Old Feb 10, 2020 | 07:51 AM
ddnspider's Avatar
Don't you know he has the highest hp cam only LS1 and highest hp SBE LS1? Show some respect! If the next post is an 8 second bone stock 4L60E I'm quitting this site.
Old Feb 10, 2020 | 08:56 AM
His other car did 480whp on the stock clutch for over 3 years and never slipped.
Old Feb 10, 2020 | 09:10 AM
ddnspider's Avatar
All I have to say is at least it wasnt called a "bolt-on".
