How tight is your PTV?
Add the potential of being on the edge of loosing valvetrain control at high rpm, wear creating larger tolerances, etc... and perhaps the catastrophic occurance of a mis-shift and over-rev...
you want the most clearance you can get.
I mean, you can run less than .080/.100 ... many knowledgable folks have done it, but they really knew what they were doing.
If you're willing to really crunch some numbers to see if you can get away with it, go for it.
I would play it safe and flycut.
My 99 T/A h&c set up had IIRC .070 on the intake & .090 exhaust with a 224/224 xer cam on a true 113 LSA. The heads had been decked and the valve job was sunk for better flow etc. That was less than expected for the cam in question. Ran great was pulled for a 416. My personal comfort limit is .070 & .090. My other set ups had good p to v with custom pistons plus heads didn't have a sunk valve job etc .090 + etc
I've never understood how you can bend a intake valve unless you drop it or have a catastrophic failure, because the piston is either at TDC or JUST before TDC when it opens.
Wouldn't the intake valve issue be based on cam timing?
I know from reading on here for years you definitely know cams, and your stuff.
A third consideration is assymtrical lobes. As many cams now are. The valves are faster off the seat and slower back on the seat. So at TDC, the intake valve is chasing the piston.
I guess the short answer to your question is yes, it is based on cam timing and valve size, but most cams are such that the intake valve is closer to the piston to begin with. So less needs to go wrong for them to contact.
That said, I know very little about the 5.0. If that head is set up with the exhaust valves closer to the pistons than the intake valves, or the angles favor the intake valves, etc. I can think of lots of ways a head could be done that would favor hitting the exhaust first. Most of what I posted is SBC / LS experience
