iron block main cap issues
Heat in the mains will cause the caps to bend. I’ve seen it a bunch. You can put the caps in a press and bend them back, machine them flat and align bore/hone the block. Or you can get a set of caps from another block and align bore/hone the deal. The second is a little easier.
You don’t see heat in the caps because they’ve been blasted.
I hope to have my bock back early August. The shop got swamped and I am in no hurry. My machinist was able to find caps that fit closely (from RonSS). He will be line honing it shortly with the ARP studs. I am confident in my shop, but not really in the block due to finding this late. Regardless, my shop wont do it if its not savable.
More to follow
More to follow
When I take a block in for cleanup I always order a magnaflux and checkout as part of the deal. no sense wasting energy on a bad block (For me that's important) . BTW the last engine I line bored was 125 bucks.. its not a big job with the right tools.
Last edited by pdxmotorhead; Jul 4, 2020 at 06:40 PM. Reason: Fixed so OP would be happier.. :)
