Callies 8 counter weight crank vs non-counterweight crank
What is the benefit of the Callies 8-Counterweight crankshaft over K1 or Summit that do not have counterweights?
Does it still require the rotating assembly to be balanced?
Does it end up more precisely balanced?
Moderator
You still have to have the crank balanced as you normally would. The center counterweights don’t exactly make the crank more precisely balanced, it more or less just counter balances a part of the crank that didn’t need to be for the power levels they were originally designed for.
The following users liked this post:
Corona (04-26-2022)
Without the counterweights, the crank can flex a lot at higher RPM and at higher power levels. The #2 and #4 main bearings start to show excessive wear and the thrust faces on #3 will too. If you’re not turning more than 7500RPM or making more than 1000whp on a 4” crank, it’s probably not going to be a problem.
Moderator
KCS, I've read a lot of your threads over the years and enjoy following your builds, anyways don't read my build thread lol, but anyways how much counterweight difference on average would you find between a stock 5.3 crank vs. a stock 6.0 or 6.2 crank in your measurements if you don't mind sharing?
I wish I could give you an answer, but I never really kept track of that when balancing cranks. It's kind of difficult anyways since the bobweights can vary so much. I think to do it right, you would need to record the target bobweight, how far off the crank is on the front and rear, and then obviously what crank it came out of. I have a stock stroke LS2 and an LC9 I'm building, so when I get the cranks balanced for those builds, I'll keep track of those and post up the results.
G Atsma (03-27-2020)
Hey thanks. I did read through your 6.2L build thread, it was really well done
You can get a Dart CCW billet crank for around $1400. Guys have machined the center weights slightly to allownit to fit in LS factory blocks.
I was under.the impression the Callies CCW crank fits with zero mods to block or crank into factory GM?
