ID this lifter
Old Apr 17, 2020 | 05:29 PM
Newbomb's Avatar
Default ID this lifter
Any idea what lifter this is? Was told Chevrolet Performance. Set of 16 came with a slightly used spring kit. Thanks!
Old Apr 17, 2020 | 09:23 PM
FourthGenCamaro's Avatar
Based on the oil hole on the side and the retainer those aren't Chevrolet Performance brand lifters. Looks like they have quite a few miles on them too, or were installed dirty.
Old Apr 18, 2020 | 09:09 PM
Newbomb's Avatar
So don’t use them?
Old Apr 19, 2020 | 08:29 AM
00cls1camaross's Avatar
Originally Posted by Newbomb
So don’t use them?
Decent lifters are less than $200 dollars for a set and the amount of catastrophic damage they can cause your engine is enormous. Get some new lifters. I had a stock LS1 lifter decide to die on me and took out my entire engine. I wasn't even racing, just out for a cruise to a local brewery.
Old Apr 19, 2020 | 09:20 AM
Originally Posted by Summitracing
OP,
As for LS7 lifters. To give you an idea of how our customers feel about them check out the 50+ 5 star reviews on the SUM-HTLSKIT. These have a higher grade lifter than what can normally be found. This kit has been superseded to SUM-HTLSKIT1. The same quality and value can be expected with the new number, its just a packaging change.
Summit sure is proud of their lifters if you can wait a month. Seems like a good deal.
Or you can have a set off ebay by thursday if you want to roll the dice with "GM LS7 lifters bulk packaged comes in plain box",
There are some on ebay right now with real GM boxes, sets of 8 for $99, but all their negative feedback is about these lifters.
I'd buy from a trusted source and cross your fingers.
Having said that about new lifters, I don't think it's a good idea to install used ones. Maybe if you bought them originally and knew they were real GM parts and they had low mileage. Otherwise no.
Old Apr 19, 2020 | 10:32 AM
Newbomb's Avatar
For $200, I probably should just buy a set of Morel 6504’s.
Old Apr 19, 2020 | 10:49 AM
Any operational differences between these and LS7 lifters?
Old Apr 19, 2020 | 02:19 PM
chevymec's Avatar
Unless things have changed in the last month, good luck getting some GMPP LS7 lifters. They have been on back order for a good while now.
Old Apr 19, 2020 | 11:16 PM
wannafbody's Avatar
I was talking today to a guy on facebook who seems to know his stuff and he uses Johnson or Morel and avoids the LS7 lifters for serious builds. He's run both the Johnson and Morel to 8500 rpm.
