Ls1 fly cutting pistons
Don't check PTV at max lift, that isn't where you are going to run into issues. At max lift the piston is way down the cylinder. The more aggressive the lobe and lift, the valve is "chasing" the piston so to speak. So the faster you open the valve at a higher rate, you are going to have PTV issues when the piston is closer to the cylinder head. BTDC and ATDC.
Everyone does it different and I'm not saying my way is the right way or the best way.
Decide what head gasket you are going to use. Slap it on there, snug the head down, check PTV.
I check it 15 degrees BTDC, in 5 degree increments to 15 degrees ATDC.
Bring the cylinder up to TDC, tape the cylinder up. Install the cutter in the head and cut whatever you need.
