2002 LQ4 Machine work bearing issue?
So I have a couple of concerns before I put this thing together. The bill came in at $3700 for block and head work which is much higher than originally quoted. I brought in the original OE main bolts figuring they would be fine to reuse but they bought ARP studs without telling me for $375. Maybe I'm wrong but whats wrong with reusing the old main studs they're not TTY and I'm not looking to drag race, then engine will be around 400 - 450 hp range I guesstimate. Are new bolts required to align bore/hone? They also charged me $170 for main bearings and the package arrived opened with one of the bearings visibly scratched to the point I can catch my finger nail on it. What really concerns me though are these cam bearings they installed. It looks like they took a sand paper wheel to two of the bearings it and reamed them out. I can still see the fine shavings around the bearing. In the pic I attached you can see this as well a scratch that I can catch my finger nail on.
So I am by no means an expert engine builder but do I have legit concerns or over reacting? They still have the heads for now and a $1000 deposit on the outstanding amount. I live in Canada so prices are generally higher up here. Would appreciate your thoughts on this situation. Thanks for listening to my first world problems.
As for the cam bearing size, yes there are different sets depending on when the block was manufactured. The old ones should be punched out and checkd for size before ordering new ones. CH10 and CH23 are the 2 sizes for the early and late Gen 3 blocks.
The OEM Main bolts can be reused and are not TTY. If the main bolts are replaced with ARP Main Studs, It is absolutely necessary to align hone the block.
As for the cam bearings, It may have been to tight and they needed some additional clearance for the cam to slide in. I have only had this happen 1 time and they had to sand the bearing to get enough clearance.
As for the main bearing the likely opened it to put in the block and scratched it when they were measuring the clearance. Bearing clearance should always be checked after machining to make sure everything is correct.
The cam bearings are sometimes tight. When a shop presses them in, the clearance is what it is. If the shop even bothers to check (which a lot do not) then oftentimes they will scuff the bearings with scothbrite to open up the clearance. It's not ideal, but it's better than not having enough clearance. I've done it and it didn't seem to cause any issues, but I always cleaned the block afterwards and wiped the bearings with acetone.
Your engine would have probably been better off if you never took it apart...
But I see this all the time, people coming from older SBC/BBC's are used to having the engines bored and rebuilt.
Ive said it 1000 times though, these newer engines are almost always better if left alone. Only exception would be if your just wanting to build a stroker or forged bottom end for some major power.
Very few have been replaced and it was always something catastrophic and normally due to lack of oil (driver fail to check it)
Me too, except where I'm from it's pickups and suv's...Now I'm not here to step on Kawabuggy's toes. All of his may have had bad rocker arms. But I've got a pile of these 5.3's and 6.0's laying around, and have used many of them unopened in builds. I may have been lucky, but I've had really good luck with these high mileage LS's.
