Cam opinion - 346 drag racing only
I will be doing 1/8th mile drag racing only
346 sbe with flycut pistons
CNCd 799s milled .025
Edelbrock ProFlo XT w 90mm TB
Similar to chris1313 pro stock ram air
powerglide w/ 8" 5500 PTC converter
9" w/ 4.86 gear
275/60/15 radial
Cam ideas?
9" w/ 4.86 gear
275/60/15 radial
Cam ideas?
Moderator
Received 1,853 Likes
what rpm you want to make peak power?
If it is "sbe" as indicated above, it better not rev TOO high.... lol
The following users liked this post:
wannafbody (07-16-2020)
Moderator
Moderator
OK....
232/238-112+5. If you're willing to put lash caps on the valves, go to .654 lift intake and .637 exhaust. if no to lash caps, then .625/.608 lift. Use 5/16 x 080 pushrods minimum. You'll probably end up with btr dual plat 660 springs.
There's my $0.02
There's my $0.02
Thanks for the input!
Moderator
you were probably expecting more like 236/244-109?
RPM on the stock bottom end, and compression ratio in the mid 11's is why i picked what I picked. Bump the compression up to 12, and that kind of cam (big duration,tight LSA) makes more sense.
I know SBC is a different animal, but my 355 had 10-10.5:1 compression and I had a 255/263 109 LSA solid roller in it that worked well. I did spin it to 75-7600 though.
Moderator
You could. You'd need to mill down to 57-58cc, which would require angle milling. With your intake, a mid 230's cam will rev into the 7600 range just fine.
7.21 @ 95mph w 1.52 60’ in 95 degree heat is what I’ve been so far. Milled/valve job 241s and LS6 intake. I’m on a mail order tune from Pat G so will be getting dyno tuned after changes.
I’m wasting money because I’m pulling this out in a few months for a turbo deal but I want to get in the 6s, would love to get a 6.70 in good air. Worried I’m gonna lose 60’
