Need some help with Hotcam
John
but to answer your question seeing as you have an 02 your pump and chain are fine. only change them out if you desire to. you can get a pump/chain/cam gasket and bolt kit from TSP for around 250.
John
Only get the hot cam if youre lookin for cam that will let the springs live 100k miles. Or want a good nitrous cam.
John
John
John
2) I got a rollmaster double roller since I was already in there and it is one of those super awesome parts you could put on a coffee table
3) valve seals so you can install the new seats that come with the kit
4) I used the JPR lifter tool from thunder and it worked awesome to hold up the lifters
5) I used one of those crowbar looking valve spring compressors from autozone. I can definitely see why people have broken bolts off in the head with them. I figured out how to modify it to work WAY better
https://ls1tech.com/forums/tools-fabrication/195158-valve-spring-tool-mod.html
