862s + LQ4= cam
Any input on this set up plus cam recommendations?
It's going to have higher compression than the LQ4 did originally, but somewhat limited flow due to the smaller valve and all that. Probably not enough to really "hurt" but enough that a "shoot for the moon" choice would fall flat.
I'd think about any of the same cams that work well in stock LS1s with unported stock heads would work well in that combo, especially the ones on the smaller side (to where they don't force the engine to have to rev way up to make its power). Something in the 224°/228° sort of neighborhood. Details would vary depending on transmission, converter if any, and gears.
I have ran both and when I switch from 706 to 243's I couldn't tell a difference on my cam only 6.0
But the 823/821 heads have good midrange and excellent topend.
The biggest advantage is also being able to run a LS3 intake, witch is comparable to the high end aftermarket cathedral port intakes.
You can purchase an entire LS3 topend for what one of high end cathedral port intakes cost.
Or if you can fit it under your hood and your not concerned with looks you can save even more money and get the rectangle port truck topend witch will make the same power.
Here's mine. I put it together myself with all used parts except for the pistons and rings as I had to have the block bored 0.065" over because it was damaged. I used LS3 style flat top pistons. I originally put it together with 853 heads and it ran very well however I had a leaky head gasket because I popped a radiator hose and overheated it (I'm very hard on my stuff I use this one to deliver pizza 4 days a week) and so I switched out the 853 heads for a set of 706 that I had from my old 4.8 l I am very glad that I did, This car still has the stock torque converter and 2.73 gears The 706 heads maximize the torque production in the stock power band area and are a perfect match for the rest of this setup with my little 212-218-115 LSA cam I couldn't be happier with it
All the flat top factory 6.0 pistons are gen 4 rods.
Several have done with without balancing and not had problems, myself included.
If I remember this afternoon ill measure the differance
