Missing while cold
Old Aug 22, 2020 | 09:04 PM
rednari2's Avatar
Default Missing while cold
I have a miss while cold. It runs great when warm. It usually takes two minutes or so before running smooth. There are no codes and I sprayed the intake manifold at start up to check for vacuum leaks. I am leaning toward a dirty AIC and not defective since there are no codes. Any thoughts??
Old Aug 22, 2020 | 09:34 PM
AFR’s ok for first couple minutes?
Old Aug 23, 2020 | 10:16 AM
rednari2's Avatar
Don't know about AFRs, meaning I do not know if the motor is running too rich or lean. My scanner only does codes and I do not have HP tuners,so I have no way to check the trims. But, spraying the manifold tells me it is not sucking air and so it is not lean.
I saw an interesting vid on you tube.The guy was having the same problem. It turned out to be a dirty AIC.
Old Aug 23, 2020 | 03:15 PM
chevymec's Avatar
Leaking injector possibly. You could always pull the rails/injectors up and place a paper towel under them. If they drip any fuel with the key on or off, you know they are leaking. Or very possible it is the intake gasket even though carb cleaner doesn't make a difference or set any codes.
Old Aug 23, 2020 | 06:43 PM
rednari2's Avatar
Nice tip about the injectors. I suppose the manifold could suck air from underneath where the spray wouldn't go.I am going to clean the AIC first and then go from there. Thanks to both of you for the input.
Old Aug 24, 2020 | 08:25 AM
gagliano7's Avatar
Take a temp gun and check all the exhaust primaries and if one is a lot lower that is the cylinder with the miss. I had a coil that would miss when cold at idle and at part throttle but was fine wot.
Old Aug 24, 2020 | 11:01 AM
rednari2's Avatar
Thats a good point. I suspected a coil earlier but moved on from there after I checked the spark while running. This was on # 1, and it was good but the motor was hot. Besides, I was thinking about a temp reader. So, going to Harbor Freight this week is in the cards.
Old Aug 24, 2020 | 12:00 PM
RB04Av's Avatar
A few drops of water on each header tube after about 10 seconds of running was what we used back in the Ice Age.
 Michael S. Palmer
Old Aug 24, 2020 | 12:03 PM
rednari2's Avatar
Smile
Yea! I usually start a cold motor and touch each pipe with the back of my finger. :-)
Old Aug 24, 2020 | 01:01 PM
RB04Av's Avatar
That would probably work fine if your nerve endings are properly calibrated but is a little too up close and personal for me.
Old Aug 24, 2020 | 02:39 PM
I use a thermal laser point gun, as you guys are talking about, on the headers up by the flange to help tune with. Lots of other uses on/under the car as well.
Old Aug 24, 2020 | 05:35 PM
rednari2's Avatar
Smile
I tried my tongue once....
Old Aug 24, 2020 | 07:07 PM
CattleAc's Avatar
Was it cold out...did it stick like it does to the flag pole in the school yard...???
Old Aug 25, 2020 | 04:49 PM
00pooterSS's Avatar
Inspect the plugs for excessive gap too. I've had that problem a few times with worn plugs. Fuel lights off much easier once the engine warms up. Could also be lean.
As chevymec said, could be intake gaskets leaking too. Had many that leaked that didn't respond to spraying with brake clean.
Old Aug 25, 2020 | 05:49 PM
CattleAc's Avatar
To bad you don't have a way to scan it...I've had a bunch come through the shop that didn't change the idle with a shot of carb clean...but, with monitoring the O2 sensor voltage, would drive them pig rich after the shot without changing the idle...
Old Aug 25, 2020 | 06:24 PM
00pooterSS's Avatar
Agree, after seeing it hardly ever work after 20 years of being a tech I've pretty much given up on spraying to find vacuum leaks. It works for me about 1 out of 20+ times or maybe even less.
I use a stethoscope to find vacuum leaks. I pulled the end off and attached a length of vacuum line to the end of the rubber hose with a vac line coupler. Then I stuck a piece of brake line up in the vacuum hose so I could also run the tip across exhaust looking for leaks, it works really well on vacuum leaks, exh leaks, I even use it for evap leaks sometimes.
Old Aug 25, 2020 | 06:58 PM
Brilliant!
Old Aug 26, 2020 | 11:28 AM
LilJayV10's Avatar
Trying to find a vacuum leak with something with 02 sensors is pointless unless you are watching the 02 voltage and STFT. The PCM will immediately pull fuel out and you will not get the increase in RPM's like you will trying to find a leak with a carb engine.
You can also use a water bottle, drill an 1/8 hole in the cap, point and shoot. If you do have a leak, it will suck with water in and no you won't hydrolock your engine.
Old Aug 26, 2020 | 11:41 AM
00pooterSS's Avatar
That works too. I start by watching STFT and LTFT, if I see overly positive number I know I likely have a leak.
Che70velle, this thing is wonderful for pin pointing, and I mean pin size hole pin pointing, leaks. Here's a pic of how I arranged it. I recently found a intermittently leaking bypass actuator on a whipple blower with this after the truck went to a couple shops and they couldn't find it. Some people like smoke machines but if it's a small leak it won't smoke enough to see the leak, but you'll hear it like a heavy wind noise through the stethoscope.
Old Aug 26, 2020 | 02:02 PM
I’m gonna build one of those. I like the hard line at the end for heat, but better yet accuracy. Sometimes plastic will rub and it makes its own noises. The metal line wouldn’t do that...I wouldn’t think.
