What gains can I expect 317 to ported 243
Just wondering how much (ballpark) HP can i gain by switching to CNC ported 243/799 heads.
Fresh LQ9, 317 heads
1 7/8 headers
3" exhaust
TBSS Intake
LS3 TB
54lb injectors
Cam motion Titan 4 cam
227/232
.612"/.595"
113 Lobe Center Angle with a 109 Intake Centerline
Circle D 245mm 3400 stall
Thanks
1 7/8 headers
3" exhaust
TBSS Intake
LS3 TB
54lb injectors
227/232
.612"/.595"
Thanks
The following users liked this post:
EddieK (12-21-2020)
EddieK (12-21-2020)
MASS seller approved
About 15 being head flow is very similar with main thing being going from 71 to 65ccs. With that cam, I would definitely mill and run Cometic 40 gaskets for increased compression. This will make you more power everywhere.
I may have worded that wrong. I did the cam first. Made a pretty good difference. I expected more from the heads. Maybe 20hp if I had to guess. I just remember that was a lot of work and money for such little gain. The heads flowed over 300 at .600 on the intake and like 230 on the exhaust. Think it was 226-227cfm. Really good low lift and mid lift numbers. I think at that point, heads weren’t badly needed, although they helped, it just wasn’t worth the effort/cost at the time. Would I do it again? Yea, because I’m a dummy. It all adds up but I don’t think 50rwhp worth like the op is thinking. But hey, I could be wrong. Do it and see!
G Atsma (12-22-2020)
I generally like the advice given by some to just mainly concentrate on smoothing and blending the bowl areas, plus a good multi-angle grind on both valves and seats. It has been mentioned that just the mentioned steps comprise 80-90% of gains to be had with porting, as those areas are the weakest flow areas in a stock head/valve setup.
The following 3 users liked this post by G Atsma:
Sell your 317 heads and get a pair of 243 heads. That will bring your compression up which adds torque even in stock form. If you get a ported a set of 243s you'll gain even more.
If Fontana was open, I would give time slip comparisons. Irwindale should open in 2021 so I'll take my '01 with ported 243 heads there to compare my times. I'll share then.
G Atsma (12-24-2020)
The reason you have your heads ported by someone/CNC is because it addresses the major pinch-points in the head. Usually the throat is a major pinch-point which improves flow and adds significant power. Bigger throat on intake and exhaust and more compression will add quite a bit of power to your 6.0 liter.
