Ls1 rod knock or bad lifter?
Old Feb 10, 2021 | 03:59 PM
  #41
01CamaroSSTx's Avatar
Definitely!
Old Oct 26, 2021 | 12:49 AM
  #42
Bakir Bakir's Avatar
Originally Posted by 00cls1camaross
That is how mine sounded when my lifter destroyed my ls1. Don't start it anymore, drain the oil and see what if any debris comes out. Pull the head remove the lifters. Pray the lifter just collapsed and the roller is still there (mine broke off)
Depending on the roller tip and the status of the lifter, Replace the lifters under both heads, perhaps the cam if need be, continue on with life. Punch your brother in the nuts.
yo basically only one of my lifters has any sorta damage. It jus has a scar running across it, u can see a pic in my most recent pic and also the cam looks normal to me so I’m not sure if I should jus use stock cam and replace lifters and gaskets
