Ls1 rod knock or bad lifter?
Depending on the roller tip and the status of the lifter, Replace the lifters under both heads, perhaps the cam if need be, continue on with life. Punch your brother in the nuts.
I'd pull the valve covers and look for broken spring coil pieces.
Wiggle push and pull on the rocker arms looking for something loose in the valvetrain. If you find something not right at least you'll know which head to pull first... of the two.
Not sure if you are a mechanic or not but there is a great guide on LS1howto that shows how to removed the heads. I'm a youtube mechanic so that guide was great.
--Also, as previously stated, if the lifter did turn or come apart, it more than likely messed up the lobe on the cam and thus the cam would need to be replaced or perhaps the motor like me.
Best of luck!! Here is a picture of my "tapping" lifter. I hope it is not this for your sake lol
Bru I almost have the right side valve off. Got all coils off just don’t know how to remove this hose lookin thing from the back. The passenger side is really annoying cuz there’s 2 hoses going to the back that are blocking me from remove some bolts and I can’t reach back far enough with something to release the the hose clamps..
Do yourself a favor and use www.ls1howto.com
there it will show you how to remove the manifold and then the heads. No guess work needed...
My own mechanical knowledge is limited so I don't really know how to check the lifters without looking at them aka pulling the head. I forget what person said you can tell by pushing on the rocker/pushrod side or something, perhaps he can shed more light on that.
The hose I though you were talking about was on the drivers side so I am not sure what hose you are referring to. I don't have any hoses on that side except a few PCV hoses
still haven’t done the other side, I’m not sure if this noise is normal, it only comes from some of them. I bet it’s my problem but can anyone tell me if I need to take the heads off? And I should probably check the other side right?
