lq9 build
Picked up an LQ9 that needs a little work. Had some decent pits and rust in the cylinders so decided to go .030 over but keeping the crank and rods stock. It's going to be a street-driven truck that will stay N/A and live mostly under 4k rpm. I've got the stock 317s but may end up getting some 706s in the future.
I've got two questions: I've been looking mostly at Summit and haven't had any luck finding piston sets(pins, rings, etc) that aren't forged, should I just go with those even though I won't be making that kind of power? And second, they're milling the deck as well for straightness, does that put flat top pistons off the table as far as clearances go?
Speed Pro H1129 .75MM https://www.summitracing.com/parts/slp-h1129cpa75mm
Silv-O-Lite 3517HC .75MM https://www.summitracing.com/parts/uem-3517hc-75mm
Hastings Rings for that size piston https://www.summitracing.com/parts/hsn-2m4862030
Interesting. I thought 317s were more for boosted applications with the larger chamber?
Stock for stock, the 706 are at a flow disadvantage, they just help in increasing static compression ratio. And once you get your short block together and mill the 317 heads, you'll probably find it's plenty of SCR for a mostly street truck. Even the factory LQ9s with 10:1 were intended to run best on premium.
