Crank balancing for Gen 4 rods
Just wondering for those who have done it, how it comes out?
My engine builder says weight will need to be added to the counterweights.
It’s interesting though. 5.3-6.2 all use the same crank casting number. I can look at all 4 (have one of each here) and the balancing holes in the end counterweights are certainly different, but not radically so.
Also interesting that the LS1 crank is hollow through the mains.
I’m building an LS1. My LS1 crank is pretty groovy, not sure it will polish. So planned to use a mint 5.3 crank. The LQ4 and LS3 cranks aren’t mine.
Anyone know why the LS1 crank is hollow through the mains?
Im sure GM had a reason.
Ron
Generally in balancing, wherever you need to add weight to one side, you can remove from 180 out. So if the balancer says you need to add 20g to the counterweight, sometimes you can get lucky and remove it from the rod throw without weakening anything.
My builder pointed that out to me. The 6.0 with Gen 4 rods as well as 6.2 cranks are drilled at the crank throws. I never noticed that. I could look for a Gen 4 6.0 crank.
I’ve run into a pickle with my Gen 4 rods.
I have 8 with ARP 2000 bolts. LQ9 rods from my buddies turbo truck.
Also have 6 from an LS3 with SPS bolts. Also a turbo engine.
Torqued them all up and began measuring the big end for size and roundness.
Only a few are under the high end of the spec. Not good. But then all bets are off when used and from turbo engines.
Just for grins, I swapped in the ARP bolts into the LS3 rods. Was surprised that the size grew by .0001-.0002”.
The SPS bolts are factory type. 15ft/lbs plus 85deg. Wrench says that’s 52 ft lbs. The ARP torque to 45. Might be more if doing the stretch method.
So am now considering the Scat I beams if they make a bushed version. Same weight as the Gen 3 rods, my 5.3 crank would balance easy.
I bought a set of the full floating Scat I beams.
Bought a Titan 4 cam as well.
Ron
I am actually doing this now.... I am anxious to see how much weight in heavy metal is needed... do you have any additional insight since your original post? (I am upgrading the Gen3 to Gen4 rods & pistons, and hoping to balance it using my original gen3 Lm7 crank)..
Ron
Because I used the Scat rods which are approx 600gm, no metal needed to be added.
My builder said when using Gen 4 rods, they typically just has to weld up the orig factory drill holes. They don’t need to add heavy metal.
Ron
EDIT!!! I just saw Rons pic. So, its not actually thru the main bearing diameters/hollowed crank, it is ADJACENT to the mains. That I understand.....
