Does this crank pulley look wobbly?
Oh and Idk if it matters but if I spray some WD40 on the crank pulley the squealing goes away and then comes back a min or two later and comes back almost instantly if I rev it up.
Hopefully I will not have a hard time finding the right size 8 rib belt now
It took me 4 hours to drill 1 hole in the car and about 20 minutes to drill 1 hole out of the car
Get a good drill bit and good luck
Use a silver marker or paint pen and mark the outer balancer ring, the rubber and the inner hub to make sure the outer ring isn't moving.
Then mark the bolt and balancer to make sure the bolt didn't loosen up?
I installed 3 different LS3 crate motors and every one of them had a fairly bad belt squeak - I changed each one out a Continental belt and the noise went away.
Something worth trying?
