Hyper vs Forged piston for 6.0 build
What happened to the engine that is requiring it to need a full rebuild?
Also if your having it bored and staying N/A you might consider having it bored to 4.065 and running a set of LS3 pistons
But unless his engine had bearing failure then his crank would be fine, and if he has Gen 4 rods all he would need is pistons/rings from a LS3
I would buy a used 6.0 but I can't find one I can witness running , plus they like 1500-2000 here and that's with high miles. Anyone have a source for a decent running 6.0 engine with no problems?
https://ls1tech.com/forums/market/1948085
I purchased these higher silicon 4032 forged piston to use in my iron LS3.
https://auto.jepistons.com/pistons-329378
