Lq4 6.0 heads
If using stock 6.7cc dish pistons, you will be at around 10;1 compression with aluminum 243/799's compared to stock 9.4:1 compression with the cast iron 873's.
I ran the SS2 in a SBE LQ9 with 317's stock 10.2 compression and it ran pretty good.
I don't know what that dish translates into for CC's.
706/862 heads from a 4.8 or 5.3. Better if you have them CNC ported, and go 2" intake valve. On a standard LQ4 dished piston, these get you to around 10.6-10.7:1 CR, I believe.
243/799 heads get you to about 10.2
Now, you can also go with a 0.040 or 0.045 head gasket, this gets you tighter quench and smaller effective chamber size. And you can mill. And do combinations of these things.
From another post on here:
Here is a stock bottom end LQ4 compression calc breakdown using stock LS2/LQ4/LQ9 Head Gaskets:
72cc - 9.47:1
71.06cc (stock 317 chamber) - 9.56:1
71cc - 9.57:1
70cc - 9.67:1
69cc - 9.77:1
68cc - 9.87:1
67cc - 9.98:1
66.67cc (stock LS1 241/853) - 10.01:1
66cc - 10.09:1
65cc - 10.20:1
64.45cc (stock LS2/6 243) - 10.26:1
64cc - 10.31:1
63cc - 10.43:1
62cc - 10.55:1
61.15cc (stock 5.3 706/862) - 10.66:1
61cc - 10.68:1
60cc - 10.80:1
59cc - 10.94:1
58cc - 11.07:1
57cc - 11.21:1
56cc - 11.35:1
