5.3 need for balancing
Old Jul 3, 2021 | 12:36 AM
dave350v8's Avatar
Default 5.3 need for balancing
Hi everyone
Im new to ls motors, Ive stripped down my 5.3 and there are water stains in some bores, I see summit sell forged pistons with plus 5 thou(3.785), will these fit on my 2003 connecting rods, will I need to have assembly re balanced?
Any advice would be great !
Old Jul 3, 2021 | 04:55 PM
What are the goals for your engine? You might not need forged pistons.
It also matters what year your engine is. Gen III or Gen IV?
Old Jul 3, 2021 | 11:19 PM
dave350v8's Avatar
The motor is Gen III so I presume I'm gonna need press fit Pistons? because they are 5 thou over will that throw out my balance too much? Im intending to go turbo so forged would be best?
I was hoping to give it a hone which would save machining bores out to to the next piston size.
Old Jul 3, 2021 | 11:57 PM
Never assume. Gen III came both ways. That's why I asked the year.
Soooo.... what year is it?? Could have saved some time here...
Old Jul 4, 2021 | 02:46 AM
dave350v8's Avatar
The motor came out of a 2003 Silverado
Old Jul 4, 2021 | 06:10 AM
thedetroitkid's Avatar
Are you 100% certain the motor is a gen 3?
Are your connecting rod caps square?
why did you tear it down ?
Old Jul 4, 2021 | 10:46 AM
If it was OE in a 2003 Silverado it IS Gen III, and pressed pin. No doubt. Floating pins came in 2004 on up.
Old Jul 5, 2021 | 10:54 AM
dave350v8's Avatar
Does anyone know if I will need the assembly balancing if I fit 5 thou over pistons ?
Old Jul 5, 2021 | 11:28 AM
Metalchipper's Avatar
Default weigh them
Hello,
Get a scale and weigh the pistons. Different makers end up with different weighs . If they are close you can lighten the new ones if they are heavier. It is hard to get an answer what they weigh before you buy them. OE pistons will probably be close.
Hope this helps.
Old Jul 5, 2021 | 05:35 PM
Does it NEED balancing to run good? Prolly not. GM never balanced it to start with. They weight match sets of piston/rod assemblys to certain bob weight cranks and throw it all together.
Having said that, I would balance it if I were building it. I always do. Heres whythe out of balanced assembly will create harmonics somewhere in the rpm powerband, and that will cause it to fight against itself, costing you performance. NOW.if this is not a performance build, and just a cruiser or woods buggy, then just send it.
Need to balance? No, in this situation. Good idea to balance? Always. Most shops are around $250 if no heavy metal is needed.
Old Jul 6, 2021 | 04:58 PM
dave350v8's Avatar
Does it NEED balancing to run good? Prolly not. GM never balanced it to start with. They “weight match” sets of piston/rod assembly’s to certain bob weight cranks and throw it all together.
Having said that, I would balance it if I were building it. I always do. Here’s why…the out of balanced assembly will create harmonics somewhere in the rpm powerband, and that will cause it to fight against itself, costing you performance. NOW….if this is not a performance build, and just a cruiser or woods buggy, then just send it.
Great info guys, I'm going to hone cylinders see if I can get rid of rust stains otherwise I'll go 30 thou and get it balanced its going to be boosted soon thank you !!
