Does this cylinder look glazed?
Old 07-07-2021, 03:30 PM
chevybayboy's Avatar
Default Does this cylinder look glazed?
Trying to figure out if the cylinder looks glazed this is the best pic I can get, I'll be rebuilding it with new rings but trying to figure out if this looks glazed.
Old 07-07-2021, 06:47 PM
Received 3,440 Likes on 2,124 Posts
If your throwing new rings at it, for sure run a dingleberry hone through it. Really doesn’t remove material and resets crosshatching for new rings to seat in with. Wouldn’t hurt to have a shop check it with a dial bore gauge…or yourself o you have one…for clearances, taper, etc.
The following 2 users liked this post by Che70velle:
chevybayboy (07-07-2021), G Atsma (07-08-2021)
Old 07-08-2021, 02:11 PM
Jimbo1367's Avatar
Is it a stroker? I agree with chevelle. At least digleball hone. At least
The following users liked this post:
Old 07-08-2021, 04:16 PM
yes it's a stroker. I think I'm just going to go a different route all together 5.3 turbo
Old 07-08-2021, 11:15 PM
wannafbody's Avatar
Can you dingleball with the pistons in or is there a chance of shavings getting around the rings?
Old 07-09-2021, 03:06 PM
Assembly has to come out. Block will need cleaned after honing entire length of cylinders.
G Atsma (07-09-2021)
Old 07-09-2021, 04:04 PM
Received 3,061 Likes on 2,384 Posts
Dude, you've been around this stuff long enough to know better than honing an assembled engine.
1) You'd only be honing less than half the cylinder.
2) Imagine the abrasive residue buildup!
3) Did you think this through???
Old 07-09-2021, 07:44 PM
I figured he was kidding, but I thought I’d play along.
Old 07-09-2021, 08:09 PM
Man, I hope you're right.... lol
Old 07-09-2021, 08:57 PM
wannafbody's Avatar
I've never assembled an engine. I assumed the dingleball was abrasive but not sure just how abrasive.
Old 07-09-2021, 10:50 PM
If it is abrasive enough to etch a cross-hatch in a cylinder, you know there will be metal and abrasive particles flying around. But besides that, how are you gonna hone a cylinder with a piston in it?? Only half or less will be done. I have never assembled an engine myself either, but if you know ANYTHING about them, common sense would dictate all I just laid out.
Old 07-09-2021, 10:51 PM
He wasn't kidding....
Old 07-13-2021, 07:23 AM
Old Buzzard's Avatar
Talking A suggestion
Back away, before you get the hone out..
Quick Reply: Does this cylinder look glazed?
