What heads to get LM7
Old Jul 23, 2021 | 11:48 AM
ChadCroucher_0102's Avatar
Default What heads to get LM7
Hello, I have a 99 Silverado with a 4.8 L LM7. I just bought a pro-flo 4 cathedral port intake and computer, and now I’m looking for heads and cam. In the future I am planning on doing forged stroker internals and bore if the block to make it a 383 cid. I’m looking to make something from like 600-700 hp. I’m looking to spend around $2,000-$2,500 on the heads. What would you recommend for heads and a mechanical cam?
Old Jul 23, 2021 | 12:33 PM
01CamaroSSTx's Avatar
As Darth would say when it comes to cylinder heads reach for the top shelf and he's also one of our LS1Tech cam guru's
Old Jul 23, 2021 | 12:37 PM
shakenfake's Avatar
Gonna need boost for that goal
Old Jul 23, 2021 | 03:35 PM
Fore shore!!
Old Jul 23, 2021 | 05:04 PM
Or a bottle..
Old Jul 24, 2021 | 11:09 AM
babydeuce's Avatar
Tony Mamo's MMS205 heads are the cats meow for a 5.3. They are close to the range you are looking at. I have a set, and could not be happier. He can also help you with your cam selection to maximize your combo.
Old Jul 24, 2021 | 06:10 PM
tblentrprz's Avatar
292 to 383 is a significant difference to spec a head to work well in both. What rpm is target for 4.8? Staying in 4200lb truck? Street or strip?
Old Jul 25, 2021 | 10:00 AM
Woodylyf767's Avatar
Is it a 4.8 or a 5.3? The lm7 is a 5.3
Old Jul 25, 2021 | 10:06 AM
Good catch! No such thing as 4.8 LM7....
Old Jul 25, 2021 | 06:44 PM
Neither because once it's stroked to 383 it becomes a 6.2 liter..
Old Jul 26, 2021 | 03:44 AM
1FastBrick's Avatar
As mentioned get with Tony Mamo.
Westech did a 383 build just a month ago. They used off the shelf AFR Enforcer heads. I beat they could have got higher numbers with Tony's top end package.
https://www.motortrend.com/how-to/38...p-westech-dyno
